Old 03-07-2004, 02:05 AM
saeltmarae2k saeltmarae2k is offline
Weird Headlight Problems
Well, tonight, I was pulling out of my driveway when I turned on my headlights, both worked for just a sec, and then my right lowbeam went out. I thought I had a blown fuse, so I checked the right headlight fuse, and it was fine. I do not have factory headlights (Halos), but I checked the bulb, and it looked fine. I put the good bulb (left) in the right socket, and it did not work, so I know there is another problem. The highbeams and turn signals both function as normal. I even swapped the left/right light relays to see if that would help...to no avail. What else could be causing my right lowbeam to fail?
Thanks,
-Nathan
'02 Accord EX Coupe 4c
Old 03-07-2004, 04:56 PM
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
hmmm.... that happened to my halos once but it was just a blown fuse! Are any of your wires touching one another? Some of those aftermarket halos come with a cheap material coating on the wires which wear away after awhile which could be causing a ground somewhere. Sounds like you tried all the processes of elimination already.. has to be in the wiring though...
Old 03-07-2004, 06:27 PM
Well, I figured out that my + lead was rubbed down and was shorting on the frame...a little vinyl tape fixed it right up!
-Nathan
HELP!!! Weird Headlight Problem (01 Caravan) chris j. Caravan | Voyager 34 01-27-2018 07:35 PM
96 G.A. headlights problems tinman55 Grand AM 3 11-10-2009 06:36 PM
2002 Eclipse Headlight Problem Destroyus Eclipse 2000+ 0 07-03-2009 05:25 PM
Weird headlight problem, but DRL's do work Leadhead Suburban 0 11-25-2008 09:51 PM
Weird headlight problem Nesryn 3000GT/Stealth 2 02-16-2004 12:25 PM
