Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 03-07-2004, 12:49 AM
tbraves70 tbraves70 is offline
Send a message via AIM to tbraves70
Wink supercharging
Hi i have a 2001 SS and i want to know if anyone out there has taken a supercharger off a gran prix gtp and put it on the 3800 S II? if so what do you all need to do to your car??
Old 03-07-2004, 02:05 PM
JoeJoe231455 JoeJoe231455 is offline
Re: supercharging
The process of swapping them is too difficult. You would be better off just buying an L67 (the supercharged engine) and dropping it in. You would have to replace the heads, fuel system, lower intake...engine computer...the compression would be higher. The pistons are not as strong..etc etc.
Old 05-01-2004, 06:42 PM
JAYZ KR JAYZ KR is offline
Re: supercharging
First you would need to lower your compression, change your fuel system, replace the heads, pistons and rings are questionable, modify the intake (which is peanuts), change the engine computer, lower your engine mounts (I'm not 100 % sure since it is the same frame and mounts). Your best bet would be to check with Chevy and the new 04 Supercharged SS Monte Carlo. I wouldn't doubt that you could possibly by the same set up from your local dealer. Watch it though. If your vehicle is under warranty, it will be voided in no time. All in all, the modifications you are looking at would cost you around $6000 to $8000 Canadian.
oem supercharging a non supercharged 3.8L ss stryker0220 Monte Carlo 14 05-29-2019 05:17 PM
how hard is it to make an n/a x a supercharged x with factory supercharger cooleyvette Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-10-2005 11:17 AM
Supercharge or no Supercharge? friday86 Grand AM 2 06-28-2004 03:26 PM
Supercharged vs. non supercharged mikegee Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 11-12-2003 04:23 PM
Supercharging a Non-Supercharged 3.8 1994 Park Avenue Json Park Avenue 4 11-07-2003 05:54 PM
