Old 03-04-2004, 11:29 PM
yokaze yokaze is offline
engine spec question
i've recently begun to study up on the whole engine mod/swap scene, and there's one piece of info i can't find anywhere. can anyone tell me where i can find out the weights of D series engines, specifically the D15B7? it seems to me that the weight of the engine is a significant factor in determining the results of a swap.
my thought is if i swapped from the D15 to a B16 or 18, the weight difference may seriously impede its handling, but i'm not really sure what the weight difference is. maybe i'm wrong, i still have a lot to learn.
thanks.
Old 03-05-2004, 06:37 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: engine spec question
I don't know the engine weights, but the Del Sol's were designed to hold a D-series and a B16A so neither will impede your performance. The weight difference between a B16A and a B18x is negligible.'
You really only need to concern yourself with engine weights if you are considering an H22 swap, and even then the engine weight isn't that large of a factor. People who swap H22's usually focus more on engine pitch and space constraints within the engine bay.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 08:15 AM
4.3l cross-platform Engine swap questions. Jeremyj Performance 2 04-26-2010 11:36 PM
1985 Delta 88 engine specs and Carburetor Question BrettK Eighty Eight 1 03-30-2003 08:23 PM
ENGINE SPEC Questions 1990civic '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-26-2002 01:03 AM
Engine Specs TheRED_worM Engineering/ Technical 8 12-27-2001 07:36 PM
