Old 03-04-2004, 11:56 AM
jayballa305 jayballa305 is offline
Send a message via AIM to jayballa305
Car Wont Start,Coolant inside cylinders
Last week on friday i was going to the gas station to put gas ,bcuz i was runinning on E.My car shut off right infront of the gas station.I tried to start it again an white smoke started coming out.Then i put gas and it wouldnt start.The next day i took out the spark plugs and saw coolant in side the 1st and fourth cylinder.If anyone knows what the problem is please help.Also did a compression test.All the cylinder compressions where different.One was 40, 90, then 60.Is this the head gasket.My car has never overheated.D15B2 sedan
Old 03-04-2004, 12:04 PM
91civicDXdude's Avatar
Re: Car Wont Start,Coolant inside cylinders
40?? 90?? 60?? wow, that is low.
you should check the head gasket first of all...
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
headgasket go boom....
yes u have the symptoms of a blown head gasket
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-04-2004, 12:42 PM
Also there is no mixture of oil and coolant,,,it is just coolant
Old 03-04-2004, 01:06 PM
compression test was dont off of engine starter,Not an actuall compression test
Old 03-04-2004, 02:14 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
leakdown test, head may also be warped.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-04-2004, 05:38 PM
JimCRX's Avatar
JimCRX JimCRX is offline
Most likely it would seem like the gasket. If you know how to take the head off, get it off and have taken to a machine shop. You might have cracked the head or warped it. You'll be able to tell is teh gasket it bad when you remove the head..
Old 03-04-2004, 06:43 PM
ahzab33 ahzab33 is offline
I had the same problem. It would start up fine the first time of the day, but drive it a while, park, get out to get some gas or something and try to restart it and it wouldn't start except after a few minutes of effort. I knew it was a bad head gasket because I could smell coolant being burnt out of the tail pipe along with the white ploom of smoke.
I'm actually finishing up my work on the car now. I'm replacing the gaskets (head, intake, exhaust). I also discovered cracks in the radiator hoses so those are being replaced as well.
Old 03-05-2004, 10:33 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
same with me, blew my head gasket, and decided it was woth ditching the engine for a b16. Its still in the garage from that choice. It has taken over a month for them to get the parts from hasport.
Good luck, Evan
Old 03-05-2004, 10:56 AM
88dxhatchslammed's Avatar
88dxhatchslammed 88dxhatchslammed is offline
sounds like your head gasket is blown, same thing happended to my friends crx. not to hard to replace though, should go easy
88 dx hatch
dropped 4 inches
brospeed exhuast
intake
projectors
pic coming soon
gunmeatle strut tower bars
selling camaro
just got a 2004 civic coupe, sad to see hatch go will miss it.
Old 03-05-2004, 11:30 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
it sounds like a blow head gasket to me....
oh wait, that's been said already
here is the info we gave ahzab33 on how to fix it. http://www.automotiveforums.com/vbul...d.php?t=193301
as setanta & i mentioned in that thread, it is important you check for warpage and have stuff machined. or you'll just end up with another blown head gasket in the near future.
to be totally honest it may be easier and cheaper (in the long run) to just drop in a replacement d15 or d16.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-06-2004, 12:04 PM
What is the best thing to clean cylinder heads and cylinders with.Also a good polishing formula
Old 03-06-2004, 12:19 PM
amy@af's Avatar
Re: Re: Car Wont Start,Coolant inside cylinders
you use a bit that goes onto a drill. it's a rubber piece. i dunno the "name" of it. i'm sure somebody around here does. you can't stay in one spot too long or the block will heat up and wrap in that spot. you need to move around while working.
Old 03-07-2004, 05:54 PM
Im took off the head and it was the gasket.My gasket was leaking in 2 places by the 1st and 2nd cylinder.I have to clean the top of the pistons and cylinders ,Its black i cant see any crome.Any1 know a good consontrated solution to clean
Old 03-08-2004, 11:07 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Gen Info - Just incase any coolant ever does make it into the block. Just make sure it gets flushed out with enough oil changes, to get it all out. Otherwise it will destroy the bearings from the reamining coolant, due to the oil being contaiminated....
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
2002 Passat 2.8 wont start and only hitting on one cylinder jenseay72 '97+ 0 01-08-2011 02:33 PM
My Fiat Punto Car Wont Start Ilhanx64 Punto | Idea | Punto Grande 2 10-21-2010 06:14 AM
Car wont start ethan-erickson0015 '96-'00 Civic 3 04-24-2010 10:22 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
