Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-04-2007, 04:31 PM
johershey johershey is offline
Post 1995 Bonnevillle OBD reading
if anyone could help i have a 1995 bonneville that is obd 1 but has a obd2 plug connector and i tryed hooking up a obd 1 & 2 compliant scanner and it won't read it if anyone know how to read codes i would appreciate it.
Old 09-04-2007, 05:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1995 Bonnevillle OBD reading
What kind of scanner are you using? Does the scanner have OBD 1.5 specific software installed for a 94-95 Bonneville?
Old 09-04-2007, 05:50 PM
it was a Equus Innova 3120 C.A.N. OBD 1 & 2
would you know of any particular one that would work for me
Old 09-04-2007, 06:11 PM
HotZ28's Avatar
AF Moderator Elite
Wink Re: 1995 Bonnevillle OBD reading
I use a Matco Tools 9640B professional enhanced scan tool on the 94-95. It is actually a KAL or Actron built unit. Actron has a similar unit # CP9150 that will work the same as the Matco. Of course, the Tech 11 and Snapon MT2400 with key #7 will work, but are much higher priced.
Click Here and Here for more info on the Actron CP9150.
BTW, The Equus 3120 can perform diagnostic scans for the following OBD I vehicles:
  • General Motors: all 1982-1993, and some 1994-1995 models
  • Ford, Lincoln, and Mercury: 1983-1995 models with EEC-IV systems (KOEO, KOER, timing check, cylinder balance test, output state test, and wiggle test)
  • Toyota/Lexus: 1991-1995
  • Chrysler/Dodge/Plymouth: 1984-1995
  • Jeep: 1993-1995
Old 09-04-2007, 06:25 PM
thanks for your help i'll give that a try
Old 09-07-2007, 09:29 PM
crazy8 crazy8 is offline
I have a 95 Bonneville and I use an Auto Xray codescout 2500 with the mfg. specific cable, (blue). The car has and OBD I module but uses an OBD II connector(transitional).
Old 02-20-2008, 11:13 AM
papajohn51 papajohn51 is offline
Maybe a little late but Try the AutoXray AX6000, use the blue manufacture specific cable, says it will read the codes on 94-95 GM with OBD2 plug mated to OBD1 compliant systems. (This unit was under 400$ at Etool box dot com,, if I recall correctly)
Old 02-27-2008, 11:33 AM
Jrs3800 Jrs3800 is offline
Yes the 1994 GM C and H bodies used the OBD2 Connector, and OBD2 codes and was OBD 1 Compliant.... Most Actrons I have used will read the 94-95's without a problem..
Old 02-27-2008, 12:43 PM
Yes I found a P0101 for MAF sensor out of range,, but when I tried to read the data stream I received the message: Vehicle not responding.
I am using the AutoXray AX6000 on the 95 VIN K Pontiac Bonneville..
Going to be contacting AutoXray and see what else I need.
Old 02-27-2008, 07:09 PM
HotZ28's Avatar
AF Moderator Elite
Good Luck! You could have purchased an Actron CP9150 for $150.00 and would not have to "be contacting AutoXray and see what else you need"!
Old 02-28-2008, 01:27 PM
And your response is helpfull ??
And you're the moderator??
Old 02-28-2008, 03:15 PM
HotZ28's Avatar
AF Moderator Elite
Thanks papajojn51, but I offered my advice 6-months ago in post #4. This thread was inactive & should have been closed when you resurrected it on 2/20 - in post #7.
BTW, in the future, please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If the thread is more than three (3) months old and without recent relevant feedback, please avoid adding additional post to the thread. Thank you for your cooperation.
Closed Thread
