Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-04-2004, 10:10 AM
luisguzman23 luisguzman23 is offline
Where is the flasher relay located ??
The turn signals went out on my 1998 aurora. I belive it is the flasher that burned out on it. I called a dealer to see how much they would charge to replace it & they said $95-$120 which is outragious. the part its self cost $7.00 at any parts store. But I don't Know where it is located on the car. Can anybody help me out with that info? I would really appreciate it.
Thanks,
Luis
Old 03-08-2004, 02:10 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Where is the flasher relay located ??
Take off the small black panel that is screwed to the lower dash area under the steering column, get under there on your back with a small flashlight and look straight up and you will see the factory silver thermal unit held in place by a spring metal clip. Easy R&R. Pay the extra couple of bucks and get the electronic flasher, it's not affected by temperature and you can run LED replacement bulbs with it.
Quality isn't expensive, it's priceless.
Where is the headlight relay located on a 93' Caprice 9C1? mrwrong Caprice 9 03-24-2008 08:39 PM
where is the headlamp relay located mikeyivan Impala | Impala SS 1 03-23-2008 03:15 PM
where is the flasher relay Bryanwhi Venture 2 11-29-2005 08:55 PM
Where is the horn relay located? Scooba1973 B-Series/Bravo/Bounty/Drifter 2 06-25-2005 10:52 AM
1989 Ford Taurus: where is the Horn Relay located? CannonForder Taurus | Taurus Wagon 0 05-11-2005 06:29 PM
