Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 03-04-2004, 08:02 AM
rollhard rollhard is offline
Send a message via AIM to rollhard
Passat Rear Brakes
Hi everyone,
After reading all the posts about the passat's rear brakes i guess it is normal for them to wear out so early on in the cars life. My friend has an 02 passat with only 19k miles on it. I was changing her rear pads but am having problems trying to get the rear brake piston to go in. When i turn it clockwise it goes in a little bit then stops. It would spin and spin but would not go in any further. Someone mentioned to that i need to pump the brakes 20 times to disengage the abs? Any help would be greatly appreciated.
Old 03-06-2004, 08:35 PM
boschmann boschmann is offline
Re: Passat Rear Brakes
Ther are special tools to put pressure on the piston while turning.
Old 01-03-2005, 01:58 AM
hauker hauker is offline
Even better ... go to Autozone and get the tool there (~30 bucks) ... use it ... and return it again.
They actually suggested this procedure to me themselves - and the tool looked accordingly ... nevertheless, I had a perfectly working "turn-and-press-at-the-same-time" tool for 3 hours and they took it back with no problem.
A warning: When I changed my pads I (of course) used non-VW ones (lot cheaper) -and I didn't realize that there were two lips (one on each side) that had to go beneath the pads to apply pressure. - While my job worked fine for weeks, at some point I started hearing a rattling noise coming from the outside rear of the car ...
After weeks of not beeing able to locate it, I took it to the dealer and they quickly found two things: The non-VW pads and the fact that the lips were not were they were supposed to ... "who did this?" - I was kinda embarrassed and in a hurry, so they did it for me - and charged for a regular brake job (2 man-hrs) ... although it took them 20 min! An expensive ($160) lesson learned ...
2002 VW Passat rear brakes JLFromme '97+ 5 09-23-2012 08:28 AM
2003 Passat Rear Brakes CJC12 '97+ 1 11-22-2006 12:07 PM
2003 1.8 Liter Turbo Passat Rear Brake Pads chouxmein '97+ 1 03-01-2005 12:07 AM
2002 Passat Rear Brakes Rosignl '97+ 1 09-02-2004 07:50 AM
2001 Passat - Rear Brakes passat01 '97+ 1 08-19-2004 04:17 PM
