Old 03-04-2004, 07:24 AM
QuiksilverGT QuiksilverGT is offline
CAI / WAI Intake design plans
I want to build a CAI/WAI for my GPGT does anyone have the design for one I could use to build mine. also include where to get the right materials, and after installation what to do with the PCM? its probably not a good thing to leave it hangin out.
Old 03-04-2004, 09:21 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Personally, I wouldn't go with a HAI. However, I realize not everyone wants to spend the money for a prefabbed CAI. Do a search on the national GP board. There's a ton of threads about home-made Fender Well Intakes.
As for securing the PCM, you can buy a factory PCM tray for the 2001 Blazer for around $10. It works well in the GP. The GM part number is 15995679.
Good luck.
Old 03-07-2004, 02:09 AM
JoeJoe231455 JoeJoe231455 is offline
Re: CAI / WAI Intake design plans
Fenderwell intakes kick ass. Accept no substitutes. This is mine...and I'm sorry to say they are no longer made...
Old 03-07-2004, 08:53 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Check this out http://www.zzperformance.com/zzp/inf...ns_airflow.htm
It explains breifly why adding bends to the intake is not really good.
Also check http://easyperformance.com/, under the tech info section look for CAI Design Primer. They explain you why you should not have the filter too far from the TB and why adding bends to it instead of helping you would harm you more than you think.
JoeJoe of course your setup is a lot better than the OEM airbox but would not harm to have the filter enclosed in a CAI closer to the TB.
Check mine out, is not as good looking as yours but works.
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
98 3.8L upper intake designed to fail j cAT Monte Carlo 20 03-19-2010 10:19 AM
cold air intake design notaricajustfasta Cavalier 22 08-12-2006 12:32 AM
cold air intake design notaricajustfasta Cavalier 1 07-29-2006 11:07 PM
