Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-04-2004, 01:23 AM
AndyMc AndyMc is offline
injector pulse (lack of)
91 305 TBI no pulse at key on. Squirt in gas, it will crank and run. 12 volts on one side of connector, .9 to 1.2 on other side. pulses noid lite after you get it started. No cam or crank sensor. Grnd is good. Hair is leaving FAST. Help please. Thank You
Old 03-04-2004, 03:41 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: injector pulse (lack of)
like 99% of all the chevy's that break down your fuel pump died. if the box isn't full of crap you can unbolt it, unhook the lights/filler tube and slide it back to access the pump or remove the tank.
try beating on the bottom of the tank while a buddy cranks it sometimes you can temporarily fix it this way.. good luck to you!!
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
Need input on trans service(or lack of) George G. Rodeo | Passport | MU 8 06-28-2005 02:12 PM
no injector pulse bill8239 Escort 3 07-31-2004 02:38 PM
No Spark, no injector pulse, no fuel pump mbaker General Discussion 1 06-12-2003 02:34 PM
