Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 05-18-2003, 08:57 AM
mbaker mbaker is offline
Unhappy No Spark, no injector pulse, no fuel pump
I have a 96 Grand Cherokee. I parked it last night and then went back out this morning to start it and...no dice. There is no spark, no injector pulse and the fuel pump does not run. The engine will crank just fine. My mechanic hooked his diagnostic computer to it, and it said 'no communication'. In the manual it said that this might be caused by a basic vehicle computer failure. The problem is, that I can't find anything that Jeep actually calls 'the computer' in any of the manuals (including my Chilton's Manual). There is a Powertrain Control Module (PCM), an Engine Control Module (ECM), etc. But which is the 'computer'? I found a silver, aluminum box mounted to the right side of the firewall behind the coolant reserve bottle. I removed it and took it to two parts stores, and neither could match it up with anything. It has a bunch of numbers on it, like JJ700GWR, P6041, T1925, ZBSAA and a large 172. On the mounting bracket for this device is the number 56027599. Nobody seems to be able to find these numbers. Also, the ECM is apparently located behind the dash and has some of the air conditioning or heater ductwork ncorporated in it. Is either of these devices 'the computer', and would either of them account for the problems I am suddenly having? This Jeep has 199000 miles on it, but it was running absolutely perfectly before this happened. Fortunately, I got it the whole way home into my driveway before it had problems.
Mike Baker
Old 06-12-2003, 02:34 PM
tjganger tjganger is offline
Send a message via AIM to tjganger Send a message via Yahoo to tjganger
i have an 88 cherokee the ecu is what you need as far as i know i have the same problem but my fuel pump is working as for where the ecu is it should be under the drivers side of the dash as long as it is in the same location
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
