Old 03-03-2004, 10:38 AM
molina_aitor's Avatar
molina_aitor molina_aitor is offline
Question Air brush
I am planing on buying a compresor and airbrush to paint my models and RC bodies. I am new to this field so i have a couple of questions. Firstly i was thinking of buying a "airpress" HLO 200-25. its specifications are 1.5 HP or 1.1 KW, 200Liter/min, and 25liter tank capacity. This would cost 100 euros. Is this a good price/quality ratio? Can i hook an airbrush to it? Thanx for ur time.
Old 03-03-2004, 04:45 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Just had a look at the specs on the side of my Holding compressor and the ones you quote seem more than adequate, Just make sure its fitted with a regulator so you can crank the output pressure up and down as you need it. Mine didnt originally and I had to buy seperate, this added £15.00 to the price.
Old 03-04-2004, 10:17 AM
Thanx. Do you know if any airbrush will fit on any compresor? And what should i look for in an airbeush?
Old 03-05-2004, 02:10 AM
Verminator's Avatar
You can usually get any brush to fit any compressor as airline to commpressor fittings tend to be fairly universal, if not some form of adapter/reducer can be found either at your supplier or hardware store. With regard to airbrush its all down to personal taste, but for a first brush go for a single action they are less complicated, try and get one with a metal body they are more durable. Also look for a kit that comes with alternate nozzles if possible to gives you more flexibility. My single action is a Badger 100 and i've had it fifteen years with only a few small repairs to washers etc. I also have an Aztek double action which is great for fine work (when its not leaking) but as I say its personal choice. Good luck
got a new air brush.. what kind of Air Compressor do i need? Hustle_187 Car Modeling 2 04-14-2005 09:28 PM
For those don't have air brush, how many spray can you use painting a model? yellow15 Car Modeling 28 07-05-2003 08:12 PM
Air Brushing With A Spare Tire dudez316 Car Modeling 8 06-12-2003 02:23 PM
Cheap Air Source for AIR BRUSH dudez316 Car Modeling 4 06-03-2003 10:13 PM
Air brushing nail polish srlxy Car Modeling 5 03-26-2003 02:59 PM
