Old 06-11-2003, 11:58 PM
dudez316 dudez316 is offline
Air Brushing With A Spare Tire
The hose on my air brush is about 1/8 inch wide and i would like to attach it to spare tire for my airsource. Does ne body no of a website of place where i can get an adapter for the airbrush to attach it to the tire. I was wondering if this would work but im not sure if its the right size since my the hose is 1/8 inch.
http://www.currys.com/airaccessories...SubAcccatID=32
Old 06-12-2003, 12:35 AM
chipanggo's Avatar
chipanggo chipanggo is offline
try www.badgerairbrush.com
Old 06-12-2003, 12:39 AM
TURBOSATURN's Avatar
TURBOSATURN TURBOSATURN is offline
Ive never herd of this tecnique does the spare tire replace the compressor??
Old 06-12-2003, 12:59 AM
chipanggo's Avatar
well yeah. but you gotta go to the nearest gas station to refill your spare tire.
Old 06-12-2003, 02:05 AM
crismag crismag is offline
ive been planning to do this technique myself
Old 06-12-2003, 03:02 AM
ales's Avatar
ales ales is offline
Forza Schumacher
The words "dirty dusty air" come to mind. I was thinking about this tecnique when I got my airbrush, but it just didn't sound like something I'd be satisfied with. The air supply is quite limited, and secondly, it will be very dirty. Or are you planning to filter the outgoing air somehow?
Old 06-12-2003, 03:21 AM
chipanggo's Avatar
i really don't use this technique. i have a small a/c freon tank which i use instead of a spare tire. it's cleaner, more handy, and packs in more air.
Old 06-12-2003, 12:35 PM
MaukaRunner MaukaRunner is offline
Send a message via AIM to MaukaRunner
Automotive Air Tank
You could also use a automotive air tank. It looks like a slightly smaller compressor tank. Get the fittings to match it to a airbrush. You can also get a regulator to regulate the air pressure. The only disadvantage is you have to go to a gas station to fill it up and sometimes the gas station's compressor only goes up to low pressure such as 60-80 P.S.I..
Old 06-12-2003, 02:23 PM
Mopar Marc Mopar Marc is offline
Send a message via Yahoo to Mopar Marc
I would suggest going with the air tank, I got a 7 gallon air tank for about $20.00 and a 1/4" regulator for about $16.00 and the tank was good for (if I remember right) 200 p.s.i. and it was easier to work with and will probably take up less room than a tire. Just my 2 cents. HTH.
Marc
Restoring my 1968 Charger
Models I am working on:
Li'l Gasser Show Car
1968 Plymouth Roadrunner ProStreet
Building a paint booth (almost done)
Mopar or No Car
