Old 03-03-2004, 05:20 AM
phonedrn8 phonedrn8 is offline
Send a message via AIM to phonedrn8
stock radio upgrade problem
Hey i have a 01 tahoe LT w/ factory sound system. I want to upgrade to aftermarket mobile videoand sound screen, tha retracts in and out of dash.
1. how hard is it to remove?
2. will onstar still work? it works thru the radio i think..
3. has anyone install a mobile video in stock location and not had any problems w/ gear shift lever in parked postion?
Phonedrn8
Old 03-04-2004, 10:42 AM
GTRhino24's Avatar
GTRhino24 GTRhino24 is offline
I've seen a Tahoe come through the shop with a fold-out unit in the dash so obviously it can be done, however, the gear shifter was touching it in the park position and effecting the position of the screen. I would suggest looking at a remote mount monitor instead. What it lacks in coolness it will make up for in practicality.
Ryan
96 Tahoe 2Dr 4x4
315/75/16 BFG ATs (Yes, they will fit.)
2.5" Skyjacker Suspension Lift
2001 Tahoe LT Rims
Old 04-28-2004, 10:19 PM
AUTOSTYLEINC AUTOSTYLEINC is offline
Send a message via AIM to AUTOSTYLEINC
Re: stock radio upgrade problem
If the vehicle is in park you will have an issue with the monitor flipping out but if it is in gear there is no issue.. If the monitor is already flipped outa nd the vehicle is put back into park it is fine. If you have onstar you will require an onstar bypass module since onstar uses the stock radio to distribute its sound. Your vehicle will require one of two modules. Here are the models of the SoundGate product and the descriptions so you can decide which module you need. OnStar interface designed for use in system installs where only the factory radio is being replaced. Equipped with simple wire leads for use in
non-General-Motors vehicles.
Click on "Application Guide" button
at left for exact applications.
Part# STARMOD2 OR STARMOD1V2
OnStar interface designed for use in system installs that include new amplifiers, new radio, etc. Pre-wired with General Motors 9-pin connector.
Part# STARMOD1V2
most likely one is for weather you have a bose system or not as well. So keep that in mind.
Kevin
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
mp3 direct connection w/ 2002 Xterra stock radio? typal Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 11-10-2009 10:47 PM
Weird stock radio/speaker problem???? tr10av Car Audio 6 05-22-2009 11:23 PM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
04 TB Radio upgrade problems steamer482 TrailBlazer | Trailblazer EXT 3 09-22-2006 11:29 PM
