Old 03-02-2004, 11:01 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Transfer case swap in '84 Cherokee
I have an '84 Cherokee with a 2.8 liter V6 and the stock 3 speed automatic trans. I would like to swap the troublesome New Process 229 transfer case ('Selec-Trac full time 4 wheel drive) with the part time 4 wheel drive transfer case (Command Trac), that was available in these Jeeps.
As I recall, the Command Trac transfer case was the base model and the Selec Trac was optional.
It this a straight bolt in? Are the mounts different? Will the existing drive shafts and shift linkage work?
My SelecTrac case uses a mechanical lever for high low and a stupid vaccuum switch for 2or4 wheel drive. It looks to me like the Command Trac has just a lever.
Any help you can give would be appreciated.
Thank you.
Old 10-07-2004, 11:06 PM
dadsdrama dadsdrama is offline
Re: Transfer case swap in '84 Cherokee
If you get an answer let me know because I have the setup in my 86 xj but i bought it used and it isn't hooked up, not for sure if it can even be used together
Old 10-08-2004, 05:52 PM
JeEpBoY95 JeEpBoY95 is offline
Send a message via AIM to JeEpBoY95
unfortunatly if you change from a NP229 to the weaker counterpart (NP209) you will have to change the front axle. in jeeps with selc-trac the front axle is a slightly different ratio than in the back and on command-trac jeeps the axles are the same ratio. otherwise the swap is bolt-in and very easy. the vaccum lines should be there on older command-trac jeeps but they stopped using the dissconect in the early 90's that is something you might consider swaping out as well.
Old 10-08-2004, 10:02 PM
MagicRat's Avatar
Thank you for the reply. It's been 6 months since this post, but in my usual lightning speed I have not done anything about this situation. It seems as if its easier just to get the original 229 case working right.
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 04:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
1993 jeep grand cherokee Transfer case swap jaggar80 Grand Cherokee | Grand Cherokee SRT8 1 01-26-2010 10:36 AM
98 Cherokee sport Transfer case swap ZeroJC98 Cherokee 1 04-08-2007 09:32 AM
