Old 03-02-2004, 02:22 PM
crxsirpr crxsirpr is offline
problem in my crx b16 help!!!!please!!!
my car sputers once in awhile and when i reach 3.000 rpm and leave it there the car tugs a few times even in 4.000 rpm but when i punch in the trotle and revs up it doesnt lose any power, wel maybe a litle. and when the car does this i punch it all the way up to 8.200 rpm and like at 7.000 rpm the car smokes alittle black, but when the problem is not there the car goes all the way up to 8.200 and no smoke. my rpm needle is at 1.200 at idle and when the problem starts it drops down to 1.000-900 rpm. the problem is intermitent. what could it be??
Old 03-05-2004, 01:10 PM
helloooooo!!!!
Old 03-05-2004, 01:45 PM
ian16v ian16v is offline
Re: problem in my crx b16 help!!!!please!!!
are b16's not bad for distributor faults?? maybe urs is faulty and causing a slight misfire and making ur fuelling go a bit iffy hence the black smoke..
just a thot
1995 Toyota Starlet GT Turbo Advance & 1991 civic b16a1 project/track car
http://www.boomspeed.com/civic16v
Old 03-05-2004, 02:59 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
are you posting any codes ?
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 03-05-2004, 05:33 PM
ahzab33 ahzab33 is offline
The last time I had that problem I had a cylinder misfiring. I turns out one of my spark plug grommets was full of oil and was causing the car to misfire. I used to have to punch the gas to get the car to budge. This was on my Toyota. Since, I changed the plugs, cleaned the grommet, and changed the oil I haven't had the problem since
Old 03-06-2004, 07:13 AM
ok the ecu doesnt throw any codes the spark plugs are new new head gasget, maybe its the distributor. when the car is cold it usually starts ruff like crank, blub blub blub broom!! it starts on the first try or second but with that problem. what could it be?
Old 03-06-2004, 01:55 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
coolant temp sensor. check it by starting the car, and when it warms up, unplug it. if the car doesnt sound any different, then its a sure thing that either your coolant temp sensor or your intake temp sensor are bad. the intake temp sensor is a small white sensor on your intake manifold, and held in by two phillips screws. when you take it out, it has a 1 inch long white probe on it, if that thing is cracked, black, funky in any way, its a good chance thats your problem.
either of these being damaged could be the problem, even without a check engine light on. the check engine light will come on if they are no longer sending a signal, not if they are sending a high or low level signal, as long as its not the maximum high or low. the ECU looks for the maximum low for a disconnected sensor, thats why i said to unplug them and see if the engine sounds different. cause the ECU will try to compensate for the sudden change in temp by riching the fuel mixture.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-07-2004, 03:03 PM
ok thanx ill check the coolant sensor and the intake sensor but is that the reason my car when is cold starts like that?
Old 03-08-2004, 05:52 AM
EF You's Avatar
EF Life Giver
probably
Old 01-19-2005, 10:39 PM
albania albania is offline
my timing belt started to slip since i hi reved it what could be the couse
can some one tell me what the problem could be
Old 01-19-2005, 10:45 PM
dont know what to go with
should i go with turbo or nitoures on my b16 crx or both dont know becouse i have hi comp piston 10.5.1 so i dont know what to and still trying to fined out what the problem is on why my timing belt keep wanting to slide of ?
Old 01-20-2005, 02:23 AM
honduhcivic honduhcivic is offline
first of all why did you bring up such an old thread?
Now to answer your timing belt question, when you push on it does it have a lot of play? Of so loosen your tensioner and get the belt tight and then tighten it back up. When you say it wants to slide off do you mean is it sliding to the side? Or is it skipping teeth? Might also be a good idea to change the timing belt too if you havent done so already.
And about the nitrous and turbo, neither is a good idea since you have high comp pistons, what kind are they anyway? Stock comp is 10.2. Forced induction and high compression = detonation.
Anti-rice leader #001
I <3 my b16
1987 Civic/CRX HF HELP jessenichols1991 '71-'87 Civic | CRX 0 05-01-2010 07:54 PM
Converting CRX to CRX HF help please hotneedle '88 - '91 Civic | CRX | Wagon | Shuttlee 10 05-16-2005 06:08 PM
B16 help please!!! CivSi23 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-23-2004 10:23 AM
problem with axle help please jamaicanbadboi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 11-26-2003 01:53 PM
