Old 03-01-2004, 09:23 AM
civicgs-r civicgs-r is offline
weird smell
when i drive...i sometimes smell like somethings burning..coming fromt the engine...my friend said it smells like plastic is burning...and othas told me that my oil might be leakin on the pipe and othas told me its my brakes..but the smell comes and goes every once in a while...do u guys know wut it might be...
Old 03-01-2004, 01:38 PM
damir831's Avatar
damir831 damir831 is offline
Banned
Send a message via AIM to damir831
automatic or manual?
Old 03-01-2004, 05:00 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
you stole my question damir. IF you drive a manual it could be your clutch.
Old 03-02-2004, 09:59 AM
damir831's Avatar
Banned
If not, maybe someone put some plastic in your engine, where the oil goes and when it gets hot, the plastic burns. You see, by adding plastic, it allows you to reach higher RPMs quicker. But if it's not the right kind of plastic, it'll smells weird, kind of like plastic. So make sure you have the right plastic in there or it'll smell like....plastic.
Old 03-03-2004, 01:23 AM
b-dogg's Avatar
b-dogg b-dogg is offline
lol
"but the smell comes and goes every once in a while...do u guys know wut it might be..."
When in doubt, I usually blame the dog!
Old 03-03-2004, 02:19 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
your car might be running hot at times. check the coolent. or you might have redlineing the car and you dont know it
Old 03-03-2004, 02:24 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: weird smell
Mine does it too, smells almost like rotten eggs/burning oil mixed. It'll even do it while just cruising.. I know for a fact my coolant level is a tad low, but I wouldn't think that's a factor. Hmmm.
Old 03-03-2004, 03:09 PM
mycivic's Avatar
mycivic mycivic is offline
Re: weird smell
Quit farting in your car guys. Just kidding.
I had the same problem. Then I read in the net that if you use higher octane rating than required by factory, it will cause that smell of a rotten egg like Ricochet mentioned. According to the site (sorry, lost the link) the smell is caused by unburned fuel and (I think) accumulates in the Cat-converter. This is I think what causes the smell. So from then on...I stepped down to 89 from 91 octane rating. After stepping down, smell was gone.
Hope this helps.
2003 Honda Civic LX
Mods: Bone Stock
Old 03-03-2004, 03:12 PM
Ricochet's Avatar
Banned
Re: Re: weird smell
Being a jdm engine, the suggested octane is 103-105 or something though.. I always use 93-94.
Old 03-03-2004, 04:00 PM
mycivic's Avatar
Re: Re: Re: weird smell
It is possible that its the unburned fuel that causes the smell.
Now for civicgs-r, it also may be possible that your burning your clutch. Are you a clutch driver? It could be a possibility that if you are...your burning your clutch that way. Or you might be pushing your car too hard.
2003 Honda Civic LX
Mods: Bone Stock
Old 03-03-2004, 04:05 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: weird smell
Hope this helps.
It also causes your cat to go bad. If you're getting that smell I would replace the cat on your car.
Empty Pockets Racing Member #1
Old 03-03-2004, 04:26 PM
mycivic's Avatar
Yeah, thats why I stepped down to 89 too. A little of inbetween. I just went on with a little bit of higher octane rating to prevent engine knocking. It doesent happen to my car but just sort of preventive maintenance on my part.
2003 Honda Civic LX
Mods: Bone Stock
Old 03-23-2004, 06:18 PM
Dysfunction3k Dysfunction3k is offline
Send a message via Yahoo to Dysfunction3k
Hey everyone, n00b here. saw this post and know i kinda had a problem w/ a bad smell also. mine was a bit different than burning plastic and oil stuff tho.
I had gone a long while w/o changing oil or adding antifreeze/water or anything, and i ended up cracking my radiator. just a small hairline crack, took it to a shop and the dude refilled all the liquids and everything, and said he'd put the radiator cap back on, but not all the way, just to keep off the pressure and keep it from blowing and steeming.
So now everynow and then when it gets low, the fluid kinda burns or whatever, and i get this weird burning pancake/syrup smell. so i carry a can of antifreeze in the trunk and just refill it whenever it gets there, or right before it empties. maybe i should spend the 300 bux to replace it, huh? but whatever, i'm a n00b, and its a fairly new car (to me). '97 civic ex, 165,000 miles on it. l8z
Old 03-23-2004, 08:36 PM
Ricochet's Avatar
Banned
Re: weird smell
Get an aftermarket Fluidyne radiator, they cost about the same as a new stock one (~$300).
Weird smell when driving fasligand Metro 1 09-29-2004 02:42 PM
problem: weird smell in the motor nsng20 Engine 14 04-28-2004 08:57 PM
Weird smell FREED0MFiST Engineering/ Technical 3 08-21-2002 09:48 PM
Weird smell Orkman Engineering/ Technical 1 01-11-2002 07:28 PM
Weird smell Orkman Accord/TSX/Accord Hybrid 3 01-11-2002 04:33 PM
