Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-01-2004, 09:18 AM
SRV BOY SRV BOY is offline
Turbo
How much maintenance is required for a turbo and what kind of maintenance is needed, I am thinking of putting a turbo on a 95 sr
that already has a h22 vtec more with the stock 2.3L tranny
and suggestions comments???
Old 03-01-2004, 01:42 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Turbo
95 sr?
well you need to be on top of oil changes and keeping the turbo cool and letting it cool off after running it hard..
1
Shift_BOOST
97 s14
Old 03-01-2004, 03:56 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
First off you're going to want keep up on your oil changes. Make sure to change that oil and filter every 3,000 miles. Using synthetic always helps; ball bearing turbos love synthetic oil. The other big thing is letting the turbo cool after driving. No matter what when you get to where you're going let the car idle for at least thirty seconds to let the oil circulate and let the turbo cool. If you drive it hard drive around normally for about five minuets then let the car idle for thirty seconds before shutting it off. That is the golden rule, always let the car idle to let the turbo cool and circulate the oil out before shutting it off.
Old 03-01-2004, 10:59 PM
honda prelude 95 sr(si)
Its an 1995 honda prelude sr thanks a lot polygon
Old 03-02-2004, 02:43 PM
Polygon's Avatar
The Red Baron
Re: honda prelude 95 sr(si)
Sure, anytime.
Turbo Turbo...Im craving Turbo! Cavyfamous97 Cavalier 51 08-14-2007 04:25 PM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 01:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 10:40 PM
Turbos Turbos Turbos 4-THGENH24LUDE Prelude 8 12-23-2004 04:31 PM
Turbo, Turbo, Turbo SI_CivicGyrl Forced Induction 6 02-18-2004 01:47 PM
