Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-01-2004, 03:45 AM
vacheresse vacheresse is offline
Send a message via AIM to vacheresse Send a message via Yahoo to vacheresse
Question 2000 impala ls
hello all! have 2000 ls and have discovered two hoses leading out of what looks like the radiator,close to the bottom,that are a little too close to the exhaust manifold,these hoses are burning,not sure where they go but it looks to me like they would be expensive too replace.obliviously there should be a heat shield of some sort ,but there isn't.fixed the problem with some high temp tape for now ,but im sur eit wont last forever!Has anyone come across the same deal? if so...can ya tell me what i need to do so this impala doesnt put me in the poor house so shortly after buying it!!!!! thx V
Old 03-01-2004, 07:00 AM
Master Tech Dude Master Tech Dude is offline
Not having seen exactly what you are seeing I can only speculate that these hoses are Automatic Transmission Cooler Hoses. They probably should be replaced if they have been overheated by the exhaust pipe because they may have become brittle and could break causing transmission failure, and yes, that crossover pipe under the hood should have heat shields on it. They could have been removed during some earlier repair and not reinstalled.
If you replace the hoses and reinstall the exhaust pipe shields you shouldn't have any more problem with this.
I'm very curious about all the other problems you have had with the car.
Let us know.
Dude
Old 03-02-2004, 12:25 AM
Re: 2000 impala ls
thx dude,will listen to all advice ya got,look in to fixing it rite away! do u know of any other suprises that may be around the corner ? heads up would be great! V
Old 03-02-2004, 06:59 AM
You can click on the link below and view a list of GM Technical Bulletins released on this model. You may want to save this for future reference.
http://www.alldata.com/TSB/10/001019FE.html
If you need more info on any particular bulletin, you can purchase a years subscription to a complete online service manual for your car at ALLDATA.com or contact your local Chevy Parts or Service Department.
Also...let us know what's going on with your Chevy!
Dude
who makes Lowering springs for 2000 impala LATIN250 Impala | Impala SS 4 10-13-2006 02:29 PM
96 Impala bolt pattern to 2000 impala MoNsTeR`ImPaLa Impala | Impala SS 4 08-22-2005 12:04 PM
FS: 2000 Impala Interior Swiss Impala | Impala SS 1 01-12-2005 12:01 AM
Keyless entry - 2000 Impala bkerlee Impala | Impala SS 6 04-01-2004 03:02 PM
2000 Impala jsonpa Impala | Impala SS 5 03-28-2003 06:37 PM
