Old 03-01-2004, 01:38 AM
LUTHER1 LUTHER1 is offline
blinking o/d light
I just had a used transmission put in my 96 windstar after driving for a few miles engine started to idle up and down and o/d light started blinking any ideas would be appreciated
Old 03-01-2004, 10:07 PM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: blinking o/d light
When the OD button flashes, that means the computer has detected a problem. It has stored a trouble code. You need to read the code with a scan tool to point you in the right direction of repair. Or look over the work that was done, to make sure all the electrical is OK.
Old 03-02-2004, 10:34 AM
rodeo02 rodeo02 is offline
Re: Re: blinking o/d light
Yep. Go to autozone to get the OBDII code read, or buy a code reader for $30-40 online or thru harbor freight tools. Like rex says, this is likely a sensor issue- range sensor, speed sensor type thing. The code will tell you.
G/luck
Joel
Old 03-05-2004, 10:53 AM
alivir alivir is offline
I just had the same problem with my 96 Windstar. I took it to a transmission shop. They had to replace the filter and change the fluid. The reason the light was on was because the filter was completely clogged up. Hope this helps.
Oil light blinking clemsonfansc Intrepid 7 03-02-2011 06:47 PM
Blinking traction control Light jeffandlinda Windstar 2 12-27-2004 03:52 PM
blinking maint. req. light when I start my Integra 92teggsr Integra 6 08-28-2004 02:39 AM
HELP!! Blinking Check Engine Light scooteringa Rodeo | Passport | MU 7 08-09-2004 04:59 AM
My blinker won't blink and tail lightes won't work deano7xi Metro 2 12-20-2003 03:11 AM
