Old 12-12-2003, 01:37 AM
deano7xi deano7xi is offline
Send a message via MSN to deano7xi
Thumbs down My blinker won't blink and tail lightes won't work
Just got this peice and the blinker won't blink and the tail lights won't turn on. Bulbs are good and the switch is good. What else can i do. Its an 89 metro .
Old 12-13-2003, 07:23 PM
geozukigti geozukigti is offline
Check the fuses. If they're good, check and see if everything in the back is properly grounded. If you have doubts, cut the ground wire from the tail lights, and make your own direct ground to the frame.
Old 12-20-2003, 03:11 AM
gungadin gungadin is offline
If I see a tail light out I use a test meter on the bulb socket to see if I'm getting juice that far. Usually I am.
My metro often gets corrosion in the bulb sockets. I get them going again by spraying and working the spring until it frees up . I also use a battery clamp brush to scrub them out. Patience and elbow grease.
Dash lights and tail lights not working, headlights and brakelights work brokenaxl Odyssey 4 07-12-2011 01:35 PM
Tail and Backup Lights NOT Working ezmak Problem Diagnosis 1 10-08-2010 09:24 AM
Tail lights not working when not in use? duhlikemanda General Discussion 2 02-28-2009 05:38 PM
dash lights and tail lights dont work! I need your help!! shockerman10 Engineering/ Technical 10 03-06-2008 04:03 PM
my guage light and tail lights dont work anonymous_1 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 09-30-2004 11:56 PM
