My wife's VR6 JettaIII started to hang in 3rd occasionally today. I know my way around cars as I build race engines (V8s). The tranny seems mechanically fine and the fluid/pan were clean, and it shifts smooth when it does shift.
Is there some type of sensor that may of gone bad?? Any advice is appreciated, Rob |
Re: Automatic tranny in VR6 started to hang in gear occassionally, ideas....???
Do you have the 096 or 01M transaxle? The easiest way to identify is the 096 has a dipstick for checking the fluid level. I've seen TSB's (Group 01, No. 97-01 & 97-05) on harsh shifting and delayed upshifting for the 01M involving improper throttle angle adjustment. It's fairly complex diagnosis & requires a VAG scanner to check out.
Re: Re: Automatic tranny in VR6 started to hang in gear occassionally, ideas....???
I looked into those TSB's again & they do relate to any 4 speed that uses the Digimat 2.1 Transmission Control Module, which should include your 096. Unless you have access to a VAG or a simulator like the VAG-COM, you would have to have it checked out by a dealer. If you do, mention those TSB numbers & the possibility that the throttle angle setting may be incorrect.
Thanks! BTW, what does TSB stand for?
Thanks again |
Technical Service Bulletin. It's not quite like a recall, just a note from the manufacturer to their technicians of a common problem & the fix, no warranty implied.
