Old 02-29-2004, 08:03 PM
thebigbr thebigbr is offline
rear main seal
hey , got a 1990 jeep cherokee, i have motor oil leak comeing out of the main rear seal.just wondering if i have to drop the tranny to fix it. i understand some cryslers have a two part joint there.
thanx
Old 02-29-2004, 09:59 PM
Rod Norris Rod Norris is offline
Rear Main Seal on 4.0 Liter Jeep
I have a 1989 Jeep Cherokee Laredo with 4.0 liter that I replaced the rear main seal by raising the vehicle so that suspension drops. I then removed the oil pan to access the crankshaft bearing caps. Loosen slightly but do not remove all cap bolts. Remove only the rear main cap and bolts. Usually by the time the rear main seal is leaking those neat little seal removers won't work because the seal has hardened. The rear main seal is a 2-piece seal. The bottom easily comes out with the cap. The piece that is on top of crank can be eased around by pushing one end until you see the other end begin to expose itself. You should be able to slide it around the journal an remove. Reinstall in reverse of what I just told you. The new pan gasket should be a 1-piece rubber gasket. Hope this helps.
Old 05-11-2004, 11:45 PM
acarguy1234 acarguy1234 is offline
Re: rear main seal
i have an 88 jeep cherokee with a rear main seal leak too but mine is ony a 3.1 will that make a difference
Old 10-07-2004, 06:59 PM
scrap_iron scrap_iron is offline
Re: rear main seal
It looks like I may try this - Do you need to unbolt the torque converter replace the seal ?
Old 10-07-2004, 09:31 PM
Dale Aeppli Dale Aeppli is offline
Re: Re: rear main seal
HI GO TO jeepin.com hey have a writeup on changing oil seal [email protected] DALE
Old 10-08-2004, 03:28 PM
Saudade's Avatar
Saudade Saudade is offline
Re: rear main seal
They do. It's here:
http://jeepin.com/features/rearmain/index.asp
I used it to change mine out ('88). The only real problem I had was getting the pan off. Seems it must have leaked a bit for a previous owner so the used sealer to stop the leak. Once I got the pan off, I had to use 2 cans of gasket solvent to remove all traces of the old gasket and sealer.
Old 10-08-2004, 09:09 PM
Re: rear main seal
Thanks for the info guys ! ...I will tackle this in a couple of weeks. I just hope that top half of the seal comes out as easy they show !
1974 comaro 350 two bolt Mains Rear Main seal pemeyer Engine and Transmission 0 11-29-2008 12:48 PM
replacing rear main seal 95 Toyota 4Runner TimT 4Runner/GX470 1 11-11-2003 06:17 PM
4.1-liter HT4100 rear main seal feuer-zauber General Discussion 0 11-22-2002 01:16 AM
Rear main seal Powerguy37 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 03-22-2002 02:12 PM
