What brand of spark plugs should I run??
I have a 99 silverado 5.3L and I've been thinking about changing out the plugs in my truck. I have been shopping around for the absolute best spark plug. Ive found certain plugs like Bosch quad-fire, zex performance plugs, or the NGK plugs. I was wondering what everyone else is using? What does everyone recomend? I need some good performance plugs.
Re: What brand of spark plugs should I run??
i would prefer the NGK plugs.
I have the Same truck, I just replaced mine last month with the Bosch Platinum +2 plugs, Truck runs sweet, very smooth, they are a lil more expensive but I am Pleased with the results.
Yeah I heard that the Bosch Platinum +2 are good to run. Thats what my local autoparts store recommended.
I like AC truck plugs.
I used the Bosch Platnums, They worked good for about 100 miles and I noticed a miss and some smoke. I pulled the plugs and discovered one of them had dropped its electrode..Thanks Bosch! Got a nice hole in the piston.....AC delco is all I use now.
i would stick with the ac delco's
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune |
ngk, denso, and ac are the best plugs for chevys, ive had bad luck with the +2's and 4's
AC DELCO, why not keep your GM, GM?
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
9 out of 10 times switching to non GM A/C Delco plugs cause drivabilty problems. I have see it to many times and would never run anything but Delco plugs in my truck.
We would see so many do it your selfers switched plugs and then the first realy cold day the truck will not start. Why because the aftermarket sparkplugs where not designed for that engine but was designed for a bunch of different engines and happens to fit a lot of different ones. Delco built the plugs for that GM engine . Who knows better then the builders what it should have |
If you are going to change plugs , DO NOT IGNORE THE WIRES. I did my plugs at 85500 km's and the wires looked fine and the truck ran great afterwards too. Long story short, wires got damaged when i changed the plugs and about 2 months later it started to run rough. I took about 2 months to find out that it was bad boots on the plug wires and it was causing carbon arcing across the porcelin on the plugs. No codes were thrown either this entire time. Ended up having to replace my plugs and wires. GM HAS ALSO CHANGED THE PLUGS THEY USE FROM FACTORY. MY 2000 SILVERADO CAME FROM FACTORY WITH DOUBLE PLATNIUM GAPPED AT .60. THEY NO LONGER USE THESE PLUGS (OBVOIOUSLY FOR A REASON) AND THEY NOW USE THE IRIDIUM PLUGS FROM FACTORY WITH A .40 GAP , NOT THE OLD .60 GAP. If you do use plugs other than AC's i suggest not going with the factory recommended .60 gap. Even the GM tech that worked on my truck said he does not use a .60 gap even if it calls for it.
**2007 Avalanche LT. ** ![]() 6" Pro Comp lift 305/55/20 BFG A/T KO'S K&N FIPK GENII Flo Pro V force muffler & 4" slash cut stainless tips Color matched front and rear Bowties 3" polished stainless bull bar and Nerf bars |
How do I remove the boot and metal surround without damaging the plug wires?
