Old 02-29-2004, 02:03 AM
(_S200_)'s Avatar
(_S200_) (_S200_) is offline
testors dull cote problems
hey, i was spraying some interior parts for my sas 350Z with testors dull cote to flatten out the colour because it was somewhat glossy and was abit rough because i had problems with my airbrush...anyways after spraying the parts the finish was not good the dull cote dried with a leathery pattern and it was not evenly dulled. i've tried cleaning the parts in brake fluid and respraying but i still get the same affect. is it because its too cold or wet outside when i spray? i know moisture in the air can cause some problems...any help? thanks and sorry for being too wordy
Old 02-29-2004, 03:02 AM
RallyRaider's Avatar
Zomby Woof
Re: testors dull cote problems
Are you mixing thoroughly enough? I've found matt coats need to be stirred extremely well to work.
Old 03-01-2004, 09:19 AM
Ken B. Ken B. is offline
Send a message via AIM to Ken B.
Are you saying you used the rattlecan dullcote or airbrushed it on? I'm confused.
Old 03-01-2004, 06:39 PM
(_S200_)'s Avatar
im using the rattle can dullcote and im getting a strange "leathery" texture
Old 03-01-2004, 08:56 PM
Vric's Avatar
Vric Vric is offline
well, from Testor spraycan, you can't exepect much..
I had this problem also the only time I tryed the Dull spray can
Old 03-01-2004, 11:25 PM
(_S200_)'s Avatar
well i guess thats it for the testors, ive used mr. super clear before and had good results with that...if only i could find some..
thanks
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
testors glass cote 67Shelbymustang Car Modeling 9 09-01-2005 10:27 PM
Testors dull cote? Ghost_9418 Car Modeling 5 10-08-2002 10:48 PM
