Go Back   Automotive Forums Car Chat > Cars in General
Old 02-27-2004, 08:05 PM
oldschool69 oldschool69 is offline
scratch in clear coat..doh
The paint is about 10 months old and was slightly scratched with some tree limbs. The scratches are only in the clear coat, it seems, and I am looking for product recommendations. It’s a black paint job.
thanks in advance..
Old 02-29-2004, 07:54 AM
galaxie500fb galaxie500fb is offline
I`ve been using mequiars #3 machine glaze for years. Takes a little longer than a cut only glaze but won`t be so hard to work out the swirls. Wool general purpose cutting pad and then follow up with a nice waffle foam pad.
Old 03-04-2004, 02:29 PM
BullShifter's Avatar
Re: scratch in clear coat..doh
If you don't have or know how to use a high speed buffer, then I would suggest an expert opinion from a good detailer. If the scratch can be felt with your nail, NO detailing technique will remove any scratch. If thats the case, sand & repaint area.
Old 04-12-2004, 09:14 PM
koeb$ koeb$ is offline
Send a message via AIM to koeb$
if it is just on the clear, and not into the actual paint, go and buy some technicians choice cut and use a electric buffer and buff the entire panel not just that single spot. if you dont buff, try to rub the compound with a soft towel
84 TA- 350 bored
dynomaax shorty headers
custom 3" exhaust
electric exhaust cut out
holley 600 cfm carb
340+HP
cam?
97 jetta
white 15" bbs wheels
2 JL 12W3's and 2 JL 500/1 amps (for sale)
Old 04-17-2004, 12:15 AM
upesleja upesleja is offline
Never your regular towel
I ran a detailing shop on the side for about 3 years and As long as the scratch did not hit the metal I could remove it. I love Mequiars products, but Without seeing a picture of the scratch or more detailed info about it, I can not tell you exactly what to use. if your worried about buffing the paint in one spot too much, or too long there are easier ways to go about removing the scratch.
First off I sugesst useing a FOAM pad when buffing, I almost NEVER used wool simple cause it heats up, and if you do not know what your doing, or stay on an area too long you can risk really messing up your paint job. Form works wonders. When you have removed the scratch, use a microfiber cloth and pick up all the splattered compound ect. If you fail to do this, you may result in putting more, small scratches in your paint when you wax it. I get my buffing pads factory direct because I got in good with a company when I was doing it for a business, but If you need some place to get microfibers, i sugest going to ultimatemicrofiber.com. I have bought from many different companies and no one can compeate with the quality like these guys.
Hope this helps, If you have any more questions on products I have used / reccomendation I would be more then happy to help . e-mail me at [email protected] and I will try to help out as best as I can!
Old 04-24-2004, 08:35 PM
mcpbw mcpbw is offline
Send a message via AIM to mcpbw Send a message via Yahoo to mcpbw
Re: Never your regular towel
[quote=upesleja]I ran a detailing shop on the side for about 3 years and As long as the scratch did not hit the metal I could remove it. I love Mequiars products, but Without seeing a picture of the scratch or more detailed info about it, I can not tell you exactly what to use. if your worried about buffing the paint in one spot too much, or too long there are easier ways to go about removing the scratch.
QUOTE]
sorry to rain on the parade, but you can not remove a scratch. You can lessen its appereance by lowering the surrounding area (compounding or wetsanding) or hide it temporarily by using a filler or glaze, or repaint. those are the only options. I know a detailer in Texas that does stunning work http://www.ultimatereflections.net/ , he is probably one of the most respectable detailers amongst many detailing forums and an honest guy to boot. If they are not too deep you can repair the area yourself, just be careful to read the directions as only a few products can be used by hand.
Good luck
Eric
It's all in the details........http://www.motorcitypoorboys.net
Old 04-25-2004, 09:34 AM
well
ANY detailer would know that when you say "remove" that’s what you mean, hide, cover up, or lessen the appearance, I would appreciate it if you kept your "flames" to yourself simply because your silly "rant" was a pointless attempt to lower my credibility. Sadly if you feel compound or wet sanding is the only way to remove a scratch then your living in the past, and you should look into better products. Contact me personally and I would love to send you in the direction you might be looking for.
Now, if someone knows what there doing with automotive detailing, and there good, then they can remove the defects and still wash and wax there car with no problems of having the defects "come back".
If anyone has any questions or comments please feel free to contact me directly, via e-mail or PM. I am more then willing to give my advice on what products are good, and also what’s works and what to stay away from. Between my father and myself, I have over 40 years experience with automotive detailing. Feel free use this to your advantage and ask away, I am more then willing to give you an unbiased opinion because I will tell you what works and what does not work, not what sells!
~Brian
Old 04-27-2004, 08:55 PM
my intention was not to "flame" you but you even said it yourself. "ANY detailer would know......." well I do not think we are dealing with a "pro" detailer here, so lets be honest and tell it how it is. you can not remove what isnt there
Eric ( and yes I am a "pro" detailer )
Old 04-29-2004, 09:05 PM
CARNIGG CARNIGG is offline
Send a message via Yahoo to CARNIGG
OKAY...isnt the rule of thumb.."if you feel a scratch with the tip of your nail the only real way to aleviate that is to do paint repair"...????
Old 04-30-2004, 01:14 AM
Re: Re: scratch in clear coat..doh
That's why I posted this^
CARNIG large sig. pic's suck for user w/ slow connection.
Old 05-12-2004, 04:30 PM
HondaOz HondaOz is offline
I have an Acura Legend, its pretty beat up, but I decided I was gonna put some love into it, but I'm kinda lost where to start, so here is a list, plz help me.
How to paint dashboard?
How to install racing seats? is 88 after all
Can I install any new kind of gauges for it?
Changing interior carpet?
How to remove stains from carpets or seats?
What are the best products for cleaning?
Check my page out, Thanks a lot
http://www.cardomain.com/memberpage/569777
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Light scratches on clear coat dianaraven Cars in General 5 01-27-2010 08:16 AM
