Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-27-2004, 05:26 PM
MACspeedTUNER MACspeedTUNER is offline
subwoofer enclosures
I recently bought a 96 grand cherokee limited and im looking to upgrade the infinity system. Im hoping to add just a bit of bass to the system but i really dont want to fill up the trunk with a box. I went to crutchfield.com to try and find a kick panel box or something like that but they only support a 6.5" speaker and i wanted at least an 8. The other option was a box that replaced the little storage area over the right rear wheel (with the cargo net) with a box but the darn thing costs over 200 bucks and i kinda like that little spot (holds all my car cleaning crap quite nicely). They did have a cool peice that went in front of the spare, held an 8 and looked almost stock but it doesnt fit with the optional full size aluminum rim.....which i have. I was wondering if anyone has found a nice enclosure that is not trunk mounted and is unobtrusive. I was thinking about making some type of sound bar that aims the subs back into the trunk area from above the passenger seats or maybe an 8 right under the glove box. Thanks for any info.
PS: looking for the leather cover for the spare wheel, dont feel like paying dealer prices or even my shops cost. My interior is the dark grey. Email me if you have one or can get one cheap. Thanks
Old 02-29-2004, 03:02 AM
i live in a box i live in a box is offline
Your subwoofer solution
It you are going to mount an 8" woofer I would suggest aiming it into the cabin. 8", though massive compared to say home audio subs are not going to give you a consistently audible sound while driving (or at least not when you're on the freeway with your windows down). I actually think that you've come up with a viable solution under the glove compartment. Build a sealed box out of fiberglass so that it contours to the firewall and any obstructions. You can find a great fiberglass runthrough at http://www.sounddomain.com/memberpage/493978. This isn't a tutorial persay but it will give an idea of how to piece together fiberglass. You can email him as well by PMing him through sounddomain.com. He returns emails and is very helpful.
I haven't looked for your box on the web because I doubt you'll find it. good luck though
Old 04-14-2004, 08:05 AM
NulodPBall NulodPBall is offline
Re: subwoofer enclosures
Just a quick thought: what about the space IN the spare tire wheel area? Yes, maybe the rubber may absorb some of the good stuff and yes you'll have to find some way to fix it in place that's removeable but...
Ray
Old 04-15-2004, 12:00 AM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
I think if you want a good stereo system with some good bass you will just have to get a nice box and some good sub's and an amp.
I have 2 Xtant 10's with a 1000W Amp on the back of the box and the box is fairly large and takes up a decent amount of my cargo area, but hey thats the price you pay for a good stereo system.
Old 04-15-2004, 01:10 PM
lukep lukep is offline
Yeah, you're probably going to have to settle with the fact that you're going to have to have a speaker box sitting in your trunk. If you get a smaller 8 or 10 inch sub, you could get a "small sealed box" that won't take up much space, and then just mount the amp onto the box. That really is probably the only way to go to conserve space.
It might be too much trouble to try to mount a speaker in the spare wheel/tire
Old 04-15-2004, 03:02 PM
bryanbrutherford bryanbrutherford is offline
This is interesting, because i was about to post the same question last week.
But since i am an industrial designer by trade, i just decided to build my own box.
I came up with some plans to use a 10" xtant sub powered by a 400 watt jbl amp in a box custom built to fit in that area in front of the spare, it'll be much nicer looking and better sounding than that 3rd party piece you refered to.
the box will accomidate the sub and an area for the amp without extending past the thickness of the spare, and with creative use of the space i was able to get the proper cubic footage the sub is rated for.
i will link up some of the sketches i did and hopefully by monday i will have it done and installed and i will hook up some photos.
my initial plan was to get an open air sub and just mount it in the spare.
Old 04-19-2004, 09:08 AM
that's it, took about 6 hours, to build and install, i put the amp under the back seat, It sounds good it isn't super loud but it does add that extra bit that thickens up the sound.
Old 04-21-2004, 01:03 AM
Good work man, that's an impressive little box you built there, but I think you need some more power for your Xtant sub, because I have 2 of those 10" Xtant subs, and I have a 1000W amp running both of them, so they are each getting at least 500w, and your only giving yours 400w.
Old 04-21-2004, 09:56 AM
Subwoofer Specifications
Rec. Sealed Box Dims: 0.50 - 1.00 cu.ft.
Rec. Ported Box Dims: 1.00 - 2.00 cu.ft.
Free Air Usage: yes
Sensitivity: n/a
Frequency Response: 30-150 Hz
Recommended RMS Power: 200W
Peak Power Handling: 400W
Impedance: 4 ohms subwoofer wiring options
Old 04-21-2004, 08:35 PM
Ok, my mistake, maybe your model is slightly different or your subwoofer is slightly older than mine, but anyways, props on that box that you built.
Old 04-22-2004, 02:57 PM
yeah, that's tight, been thinkin about building a custom box myself, but may have to go a different route than this cause of the fact that my spare tire is mounted outside the vehicle.
i'm thinkin 1 or 2 12" subs could be fitted nicely up behind the rear seat, angling upwards towards the rear glass, without losing too much trunks space.
Old 04-22-2004, 03:02 PM
lukep
it might be nice to do two 12"s on opposing sides over the wheel wells or between the wheel wells and the rear hatch.
Old 04-22-2004, 03:13 PM
Re: Re: subwoofer enclosures
Originally Posted by bryanbrutherford
lukep
yeah good thinking. i'll have to make sure to thoroughly check out my options before locking into a decision. the more I think about that, the more I like the idea.
I'm planning on rewiring my jeep's audio wiring so I can bypass the infinity power amp system sometime this spring, so that should keep me busy for now.
Old 04-22-2004, 08:58 PM
Yes it should, and in the long run, rip out that half decent infinity system, and completely replace everything, new speakers, new amps, new subs etc...
911 cutom subwoofer enclosure for sale outlaw1971 911 3 02-02-2004 01:43 PM
My new subwoofer enclosure! Pics! DarkImportGrey '88 - '91 Civic | CRX | Wagon | Shuttlee 12 08-01-2003 08:06 PM
subwoofer enclosure 94civic Car Audio 5 02-18-2002 05:17 PM
FS: ADS (a/d/s/) Porsche Subwoofer Enclosure - Black driver 911 0 02-12-2002 08:25 AM
