Old 02-27-2004, 01:18 PM
castelro castelro is offline
carburetor & computer
I have tbi on my 87 s-10 383 stroker conversion.
I'm buying a carb but don't want to replace the ignition with a mechanical advance ignition. If I put the carb on and disconnect only the iac, tps, and injector connections on the wiring harness, will the computer still run the spark correctly?? I think it should work, but I'm not sure. Also, can I use a 35 psi fuel pump if I plumb in a low pressure regulator??
any info would be great
thanks
Old 02-27-2004, 07:30 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: carburetor & computer
thanks
rpm, tps and map are used as inputs into the spark table...
2001 Montana Electrical & Computer Problems sarboz Montana/Montana SV6 2 03-02-2009 01:21 PM
2008 Valve Body & Computer replaced?? jevakat Focus | C Max 2 11-20-2008 04:21 PM
HELP!!! Carburetor & Vaccum Line moosehead4242 Problem Diagnosis 3 03-31-2008 09:07 PM
'94 Isuzu Trooper-oxygen sensor, reset (clear) warning light & computer? TrooperGoof Trooper | SLX | Bighorn | Wizard 5 02-20-2004 07:32 PM
Handling Problem & Computer Console of 1994 Chrysler T&C Pete Peters Caravan | Voyager 0 09-23-2003 10:39 AM
