Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-03-2002, 05:24 PM
XaznPKdogX83 XaznPKdogX83 is offline
Setups that can make a GSR run 300 and up hp at the wheels
I have a 98 GSR and was wondering if anyone knows how I can put this bad boy in the 300 and up hp at the wheels range. Go all out if you want, money is not a problem, if I put this over time. I don't want to lessen the weights by removing seats and so forth. Thanks.
Old 01-05-2002, 10:09 AM
integr8 integr8 is offline
Send a message via Yahoo to integr8
Thats gonna be extensive. The few streetable tegs Ive seen that high are REALLY built. Basically your gonna want to rebuild the bottom end to support huge amounts of booste (15-20psi). Thats low compression pistons, rods, maybe even balance the crank. (Mind you, an LS engine would work better for this so if moneys no object you might want to drop a B16b in there and start with that but its do-able with a GSR.) Then a turbo thatll give you the 15-20 psi of boost with all the extras. Youd probably need to massage the fuel delivery system pretty well and defintely look into a good engine managment system to handle all this. Then theres the usual little stuff like throttle body, intake manifold, ignition system...youll need all of it. You could probably even top it all off with nitrous. Its gonna be alot of work and you should have somebody whos pretty experienced build it for you....hope you have a really good tuner in your area. On the plus side, your stock trannie should actually be able to handle that much power so theres one thing you shouldnt have to mess with.
"Nice body kit, looks good in my rear veiw"
Old 01-08-2002, 02:10 AM
pvang31019 pvang31019 is offline
go here and consider this.....all done already, all you need is a turbo kit
http://www.automotiveforums.com/vbulletin/t14322.html
Can a bad clutch job disalign the wheels? Sypher0725 Engineering/ Technical 13 12-11-2006 06:20 AM
Can someone help me find this body kit? or a company that can make it? eclipseseeker Eclipse 2000+ 4 06-21-2005 05:43 PM
Can someone help me find this body kit? or a company that can make it? eclipseseeker Eclipse 2000+ 3 05-17-2005 07:34 AM
Loose Idler Wheel..Thats what makes the noise..HELP solaris=amazing Thunderbird 3 06-11-2004 02:23 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
