Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-26-2004, 09:15 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
I need your help!!!!
I'm asking for my friend, Teg w/ a B18C5.
We just finished adjusting the valves, put it back together, and put on his brand new Nology wires. He has a brand new battery. Anyway, it won't start, at all, won't even crank. We used the Haynes manual for everything. We he turns it over, the lights dim. Does anyone have any light they could shed???
Old 02-26-2004, 09:19 PM
integrasedan integrasedan is offline
Re: I need your help!!!!
did you put the wires in the correct order?
Old 02-26-2004, 09:29 PM
according to the manual we did, i mean, of course i thought of that, it's not that. We even tried different combos in case we read the manual wrong. But even w/ the wires wrong, the starter should still crank.
Old 02-26-2004, 09:34 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Has to be the battery, try top jump start it with some jumper cables. Did you leave the radio going or anything while you were working on it?
Old 02-26-2004, 09:35 PM
if you have alarm with starter kill, your alarm maybe activated. arm and disarm your alarm and try starting it.
i really don't know, other than disconnecting the battery to let it reset, maybe a short circuit or something, goodluck.
Old 02-27-2004, 12:55 AM
see, thing is, lights dim when we crank it, but then full power quickly returns, windows go up/down @ normal speed. Is it the new wires? Or did we mess sumthin up while adjusting the valves?
Old 02-27-2004, 02:15 PM
nobody can help??
Old 02-27-2004, 02:57 PM
whtteg's Avatar
Re: Re: I need your help!!!!
Originally Posted by Joseph1082
nobody can help??
Chill out man this is not onstant help, people have jobs etc you know.
Also it is hard to fix a car that is hundreds of miles away and the help given has not been tried. It has to be the battery, it takes alot more power to start the motor than it does to roll the windows up and down. Try jump starting ot or try a known good battery. Then reply back with the results.
Old 02-27-2004, 03:13 PM
wickedplastikman wickedplastikman is offline
did u disconnect any wires from the starter? there is a ground on the starter, make sure that is connected along with the other wires on the starter. if all that is ok. try to jump start the starter by connecting the battery directly to the starter. if that doesnt work make sure the timing is not off and that the cams are not stuck.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 02-27-2004, 03:25 PM
Damn, samething happen to me this afternoon!
it won't crank, just silence. I tried to start it several times. This happened before, a couple weeks ago and I thought it went away.
Anywayz I opened the hood, looked okay, test battery, it was fully charged. arm & disarm alarm couple times, just in case, got pissed and behold it started!
Don't know what the cause was, but i hope it won't return, but it'll probaly will...
try cursing and yelling at it, maybe it will start for u...
need more tourque i need your help!!!!!! marty1 LeSabre 2 02-05-2008 08:51 PM
Who have red top optima on your car I need your help ! Killa Eclipse Problem Diagnosis 20 06-27-2006 10:00 PM
Told my uncle I would help him with his Jetta, now I need your help guys ! 99_Mustang_GT Jetta/Vento/Bora 0 12-28-2003 08:40 PM
Museum need your Help!!!!!! NCMR8CMan@af Corvette 1 01-24-2001 10:01 PM
