Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-26-2004, 01:51 PM
Mrs.Owen Mrs.Owen is offline
96 Explorer break issue
The front breaks on our 96 Explorer vibrate and grind LOUDLY when breaking suddenly or on ice. Is this normal and if not what is it and how do we go about fixing it.
Thanks!
Old 02-26-2004, 08:04 PM
XLT03 XLT03 is offline
Re: 96 Explorer break issue
I assume that on the pavement you do not have the vibration and grinding noise. If this is the case, there is nothing wrong with your brakes. It's the ABS (antiskid braking system) doing its job. When you brake on the ice the brakes lockup and the ABS thinks you are skidding and releases and reapply the brakes to help keep the vehicle under control. If you have this noise and vibration on dry pavement you should get a brake inspection. From what I can figure from your posting, it's the ABS that is working and doing its job.
02 explorer break lights stay on Brutus262 Explorer | Explorer Sport Trac 1 04-16-2009 11:07 AM
breaks issue? squeek TreeFrog Eclipse Problem Diagnosis 4 05-17-2006 11:22 PM
94 Explorer break pedal grinds kennyj Explorer | Explorer Sport Trac 3 10-23-2005 07:10 PM
90 4runner break issue FBFalcons73 4Runner/GX470 1 05-30-2005 02:41 AM
2004 Explorer Break Job cmp3 Explorer | Explorer Sport Trac 2 03-03-2005 06:45 AM
