Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-29-2005, 02:09 PM
FBFalcons73 FBFalcons73 is offline
90 4runner break issue
I have an odd break problem in my 4runner. I thought it was the master cylinder, so i replaced it. The pedal was still really weak, and while bleeding the breaks, pumping the breaks made the motor start skipping and then it shut off. Anyone know what could be wrong?
Old 05-30-2005, 02:41 AM
Tomsriv Tomsriv is offline
Re: 90 4runner break issue
Sounds like your power brake booster needs replacement. It uses engine vacuum when you step on the brakes so it may have a vacuum leak which makes the engine run lean and rough.
