Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-26-2004, 12:07 PM
reilly reilly is offline
2000 si 91 teg
O.K.
Here is the problem I just bought a 2000 si bone stock and I have a project civic h/b 90 wich I swaped a 91 rs dohc 1.8L into I dumped sick amounts of money into this h/b and one of the mods was a center force aluminum flywheel and stage #3 clutch i want to see if I can swap these
clutch setups or if they are interchangeable any feedback would be appreciated
Thanks
Old 02-26-2004, 12:32 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
Nah the flywheel and clutch is for a b18 and you have what-a b16? or is it d16? either way it wouldnt work...sorry
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-27-2004, 11:48 AM
Centerforce lists the same part # for the flywheel from the 1.8 dohc to the 1.6 dohc the clutch part # are different I'm thinking because one is a cable and the other hydralic maybe because the throught bearing the # are different???
Old 02-27-2004, 12:54 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: 2000 si 91 teg
Originally Posted by reilly
O.K.
Thanks
I believe your hatch has a B18A1 in it. The '00 Civic Si has a B16A2. Both are B-series motors and I would think the flywheel would swap without problems since the majority of B-series parts are interchangeable. As for the clutch, not too sure on that. The B16A2 has a hydrolic clutch and I think the B18A1 has a cable clutch if I'm not mistaken, so you may have to purchase a seperate clutch system for your Si or perhaps just a different throwout bearing in order to use it. Someone else will have to answer that question for you.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 02-27-2004, 09:34 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
b series parts are interchangable.... the clutch itself wont matter as far as cable or hydro...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Need An Opinion On 2000 Teg Body Kit djtank Exterior | bodykits | Lighting 12 06-23-2004 05:24 PM
2000 teg removed catalytic, how to fix check engine? herbal77 Integra 0 04-07-2004 12:40 AM
2000 teg gsr vs mitsu spyder gst SpyderEclipseGst Street Racing 20 12-08-2003 08:24 PM
2000 Teg Ls Weight Vs 95 Civic Ex Cpe electric_ Integra 3 06-01-2003 09:33 PM
