Old 02-25-2004, 11:07 PM
402K 402K is offline
Question center vent cosole removal 4 gauge pod
I want to put a triple gauge pod I got from www.dsmparts.com that goes into the center console vent in my 91 gsx. In order to run the lines for the gauges I need to remove the console. So, I removed the two screws from under the lower and left (of the center dash console) trim pieces, pulled the heater/vent knobs and something that seems to be around the vent itself is still attached. I looked with a mirror and see no other attach points. If I pull any harder I'll probably break it. Who has removed this before and where is this "mystery" attach point that I
am missing? Thanks.
Old 02-26-2004, 11:33 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
did you get the screws under the trim piece to the right of the steering wheel
i have a 93 eclipse i dunno if its the same or not but i think mine has a couple screws there
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-26-2004, 12:10 PM
Re: center vent cosole removal 4 gauge pod
Yes I got those under both trim pieces but it still will not come off, surely someone has had to remove it. Pretty soon I'll have the answer when I break it
Old 02-26-2004, 11:48 PM
I figured it out, behind the center console vent is two screws which cannot be seen, on both sides inside the vent itself are two tabs which act as springs and hold the vent in. Reach in between the vents fins with a small scewdriver and unlatch the vent while pulling on it, do this on both sides of the vent and it will come out. This will expose those two screws that causes everyone to break the brackets of the center console.
Defrost vent, top center of dash, removable?? kb0nly PT Cruiser | PT Cruiser Convertible 1 01-14-2008 01:27 PM
gauge and gauge pod Igovert500 3000GT/Stealth 2 07-10-2004 06:48 PM
center floor cosole wiring splashiod Explorer | Explorer Sport Trac 0 11-06-2003 02:26 PM
center vent gauge holders mycivicisonair '88 - '91 Civic | CRX | Wagon | Shuttlee 11 01-04-2003 09:00 PM
