Old 02-25-2004, 10:49 PM
Melanie1854 Melanie1854 is offline
90 Silverado windshield wipers
My husband's 90 Silverado has wiper blades that jump (don't glide smoothly) over the windshield when used.. He has tried replacing everything over 10 years, obviously except whatever will fix it. Thanks for any suggestions! Melanie
Old 02-26-2004, 09:26 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 90 Silverado windshield wipers
check the bushings in the linkage. and possible the switch. does it do this on all speeds?
Old 02-27-2004, 12:13 AM
Yes, it does it at all speeds...I think. Will confirm and get back to you. Thanks for the ideas. I will pass them along and let you know if he has tried these things.
Old 02-27-2004, 11:43 PM
Yes, it happens at all speeds. I plan to call our mechanic on Monday to ask about your suggestions. I just learned that they replaced the blades 3 times in the last 3 days, and the arms once. I will certainly ask about the bushings (didn't know they had 'em!)
Old 02-28-2004, 12:52 AM
i'm not sure what else was changed but a bad conection at the motor or a faulty module or worn out motor will do all kinds of weird stuff
Old 04-15-2004, 09:46 PM
chrisout chrisout is offline
I had the exect same problem. even with new wipers. I have 1990 silverado 4x4. I went to kragens and the parts manager recommended the better quality wipers. He installed them for me for free. I think they were around 15.00. I dont know what they had but the wipers now move smoothly. they dont jump anymore.
Old 04-17-2004, 04:01 AM
Mork Mork is offline
You may also want to treat the windsheild itself. The glass will become dirty over time causing this problem. Regular washing will not remove it. There is a glass treatment available to bring the glass surface back to its original condition.
Old 04-19-2004, 09:13 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
If the windsheild is pitted it will make the wipers skip,I agree with Mork, you can treat your windsheild, Rain Ex will coat the glass too, I switched to the Teflon wipers and they are always smooth and much quieter than the factory rubber ones they do cost about $23 ea. but well worth cutting down on skipping and aggrivating noise. Im not a huge fan of Rain Ex due to the hazey film that you sometimes get on the glass but it is an idea that might help.
-Jimmy
Old 04-19-2004, 10:57 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
The best wipers I have yet to find are ths Bosch replacement blades. Not just the rubber insert, but the whole thing. (not the arm) I spent almost $40 on them, but man do they work great.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-19-2004, 11:30 AM
buttnekked buttnekked is offline
I've never run into this problem, but with the fact they've changed blades so much,I'm inclined to believe the problem is with the motor or the way it's mounted. I would check the bushings and also run the motor without the arm installed and see if the drive arm binds or jerks while cycling. I could be something in the wiper motor worn or binding causing the problem.
1990 Ford Probe Windshield Wipers Stuck Vertical Spidersquish Probe 1 01-25-2012 10:49 PM
Equinox windshield wiper blades Ruley73 Equinox 0 03-14-2010 06:57 AM
1998 Z71 Silverado windshield wipers Z71 city Silverado 1 07-07-2008 06:23 PM
