Old 02-25-2004, 05:00 PM
68camaro 68camaro is offline
Angry 99 silverado start and dies when cold
i have 99 siverado 3/4 4x4 when cold in mornings it starts then dies and starts and dies , then leave it for a while and will start . i have tried fuel regulator , computer, crank sensor , wire connections in dash / collum all it does is cost me more money and no fix at first it would not start below 30 degress now it wont start at 30 or 35 degress .have had it checked out by 6 mechanics with no results , they say every thing is ok or it will not fail at shops , checked fuel pump, throttle body , plugs , air flow sensor etc all ok . i need help bad it at gm every other week it seems or other shops . it has beeen going on since last winter , but only happens when cold out. please help i am sick of fixing with no results , ready to get ford or dodge.mike
Old 02-26-2004, 08:16 AM
Bubba14 Bubba14 is offline
Mike,
When you start the truck will it start and not idle?
Will it not start at all?
Will it start and misfire?
Does the service engine light come on and if so what are the codes?
ready to get F**d or D*d*e
Old 02-27-2004, 07:34 AM
not a vacum leak , the truck will start and then die like it run out of fuel and do this untill the battery dies. 68 camaro
Old 02-27-2004, 07:49 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 99 silverado start and dies when cold
Does the Security light come on and flash?
Has anyone checked the coolant temperature sensor to see if it is reading the correct temperature?
Has this bulletin been performed ?
Increased Accelerator Pedal Effort, Idle Instability (Clean Throttle Body and Adjust Blade) #02-06-04-054B - (03/17/2003)
This has helped some start/ stall complaints.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 02-27-2004, 02:03 PM
Re: Re: 99 silverado start and dies when cold
hi merlin dont know if any one checked coolant sensor . some times the security light will come on and stay on untill shut off truck but does not throw code per gm garage also the throttle body was cleaned . they think it now is the passlock in coluum about 125.oo plus labor dont know if should put anymore money in truck its becoming a money pit , also would like to know why the sending unit in tanks go bad all the time and gm will not recall. thanks mike
Old 02-29-2004, 04:59 AM
GMMerlin's Avatar
I know stuff
Re: Re: Re: 99 silverado start and dies when cold
If the security light comes on, there is a code stored...have they done a diagnostic circuit check with the Tech2?
This will list all the modules that are communicating on the class 2 circuit and if they have a code stored.
Sounds like you may have a security problem.
GM WCT
PM Me for details
91 Buick 3.3L Starts and runs great cold, but dies out after 6 mins Getovait2005 Century 9 08-06-2010 09:57 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
88 Silverado starts and dies tracmekanix General Discussion 3 03-27-2009 09:43 AM
95 GA Quad 4 Rough starts and hesitation when cold buzz14 Grand AM 1 01-27-2005 08:30 PM
