Old 02-25-2004, 03:28 PM
Blackscorpion Blackscorpion is offline
Suggestions for Complete Upgrade:V6
Hey All. New to forums, so please go easy. Bought a 2000 V6, completely stock. Rims and kit to be added mid-March. Can an SVT or Saleen engine switch out into a 2000 V6 chasis? Don't think so. Would consider buying better engine before mods, but that is what I am doing right now, asking advice.
If stock V6 is kept, what mods have you found pump out the most HP overall? Right now my stock is pushing 230hp, which I would like to get up to 300hp if at all possible. Exhaust to fit my kit is probably next after that, perhaps borlas, but I have heard good things about the flowmasters, and use to sell them as well.
Let me know what you all think. Open to any suggestions. Gonna mod the hell out of it so I can always dust my brother who believes his acuras/hondas are the way to go.
-Blackscorpion
Old 02-25-2004, 06:22 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
The best way I've seen to achive hell a power out of a V6 is a nice turbo kit. It's gonna cost you a good $4K, but you'd be happy with it. As far as the Cobra swapover goes I'm pretty sure its a bolt-in deal, but then you'll have to upgrade other things as well to handle the V8. Either way your talking some big $.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-25-2004, 08:40 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
swap the 6banger out for a stroked modular. you'll smoke any ricer than you come across =). a supercharger will cost you a little less than a turbo actually, i think you can get a good centrifugal for about 3k.
keep in mind that modulars have goofy torque curves, i personally prefer the good old pushrod smallblocks. of course, that's huge dollars for any sort of new motor or even just a stroker kit for a mod. it's up to you, kind depends on A) your patience and B) the depth of your pocketbook.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-26-2004, 12:21 AM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: Suggestions for Complete Upgrade:V6
one question, stock 200 v6 pushing 230hp, how is that, isn't it supposed to be 195 if it is "stock"??
Not trying to be a d*ck, but just saying
Old 02-26-2004, 01:45 AM
Re: Re: Suggestions for Complete Upgrade:V6
What's up Joseph? I am far from a car expert, and I know you are not being a you know what, I would ask the same thing if I thought different. Anyways, as far as I know, and I just checked right now, my stock 2000 V6 should be doing 232hp, while the V8 is like 281hp. I use to work at an auto parts store, all I did was look up stuff for my car, so I am pretty sure I am right. I think the only difference perhaps from like the 98 is that I might have smaller headers, but overall pump out some more hp. I know it is over 200 at min, how much over, can't say for sure. Pretty darn sure it is 232hp though. Correct me if I am wrong. Got any ideas for what to upgrade next, perhaps on the exhaust matter?
-Blackscorpion
Old 02-26-2004, 02:05 AM
Re: Re: Re: Suggestions for Complete Upgrade:V6
Thanks for all you guys have posted so far. I have been looking at the superchargers and turbos since I got your replies. Some questions though:
What is difference between intercooled, or not intercooled, and which is better?
Is a lower psi, like 7-8, or a higher psi like 11 better, and with or without intercooling?
When they say more hp to the wheels, that is opposed to what?
Is the difference in cost and hp worth getting the turbo, as it seems the supercharger looks like more work and needs alot more mods to get it all setup?
Thanks guys. Let me know.
-Blackscorpion
Old 02-26-2004, 06:30 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
I'm not trying to make you look stupid here, but the 2000 V6 is rated at 190hp. 232 is the dissplacment of the V6 motor, 232 cubic inches. 281 cubic inches for the V8 4.6L motor which is rated at 260 hp.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-26-2004, 07:32 AM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
Re: Re: Re: Re: Suggestions for Complete Upgrade:V6
-Blackscorpion
After coolers/intercoolers are only needed if you are pushing hi psi (14-23+). the reasoning I am told is that Your timing and stuff has to be adjusted a bit more and you actually loose hp. but gain it back with the cooler air. But at lower psi the after cooler takes too much hp away.
You can run Hi psi in that v6 if you get new pistons, heads and an intake.
Now you other option (1500$) is the Nozzle system that will get you 100-200 hp gain with nitros injected directly to each cylinder and controlled. It can be set to only "go on" at specific high rpm's so you get a huge boost in weach gear at a pre set rpm. With this system you can probabbly reach 300 hp just with new moded engine parts and another 100-150 hp with the Nozzle......??350-400 hp??
But If it were me, I would stick with the supercharger........
Old 02-26-2004, 09:38 AM
okie-chevy-man okie-chevy-man is offline
Banned
Send a message via MSN to okie-chevy-man Send a message via Yahoo to okie-chevy-man
Boost is the amount of air pressure created by the supercharger. Supercharger boost is largely misunderstood, even by some experienced performance enthusiasts.
One important thing to keep in mind with respect to superchargers is that throughout the rpm range, the air ratio of the supercharger is consistent with the engine displacement. Supercharger boost, however, is not totally constant.
This is because at lower blower speeds, the clearances between the blower case and the rotors allows for air "leakage" with some loss of boost efficiency. If your engine is not as free-breathing as it could be (because it has a stock or low performance cam, small valves, restricted ports, etc.) you will typically see the boost readings go up in the higher rpm ranges. This is because the boost the blower is making cannot fully get into the cylinders due to these restrictions, and the boost pressure starts building up in the manifold, which is typically where the boost readings are taken, therefore, artificially high readings will be observed. Interestingly, this means a supercharged engine can make more power with lower reading on the boost gauge.
Boost is a function of three things: the displacement of the engine, the displacement of the blower, and the speed that the blower is turned in relationship to the engine speed. There are a few basics to remember. Assuming a constant speed ratio between the engine and the blower, a larger blower will make more boost than a smaller one on the same size engine. As engine size goes up, boost goes down if the blower speed and blower size remain constant. Conversely, as engine size goes down, boost goes up. On a given size blower and a given size engine, boost can be increased by running the blower faster in relation to the engine's speed (overdriving) or it can be decreased by running it slower (underdriving).
Banned
BTW. what parts store did you work at so i will be sure not to go there.
Old 02-26-2004, 09:52 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
232 Is the size of the 3.8 in cubic inches like the 5.0 is 302 and like the 4.6 is 281
Sorry man the horsepower should be 190 to 19. My 95 Thunderbird 4.6 only puts out 215 no way a 3.8 puts out 232(not from the factory)
P.s. I used to have thunderbird with a 3.8(232) so I looked it up when I had it and it was 190. According to ford motor company (I work at a Ford Dealership)
Old 02-26-2004, 01:15 PM
Thanks all for the suggestions, will keep all that stuff in mind when I mod. I am not mad at any remarks here, I told everyone that I am new to what I am doing, so no hard feelings. As for what store I used to work for, they are doing bad on their own, so I guess we can just leave it that way.
Thanks all, see you all on some more posts when the questions get more specific.
-Blackscorpion
Old 02-26-2004, 04:16 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Hey go pic up a copy of this month's MM&FF. They do a cobra motor swap into a V-6 chassis article. Take a look at it give you some idea of time and cost and saves me from writing it out.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-20-2004, 07:47 AM
kaper232's Avatar
kaper232 kaper232 is offline
Send a message via AIM to kaper232
Arrow Horse Power
Stock 2000 Mustang V6 "232" is roughly.. and I emphasize ROUGHLY!! --> 190 HP.. Thats rated at the flywheel.. Not the rear wheel.
Old 06-20-2004, 08:03 AM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
ok the hp of tha car has been covered REPETEDLY, but it would be better money spent to either turbo or SC the v6 tehn to do a swap. a cobra motor and tranny are NOT cheep, and you still need the electrical and rear.
