Old 02-24-2004, 09:48 PM
Mojoe Mojoe is offline
She cranks...
she pops, but she won't fire up and run. Checked all the grounds, plugs, etc on my b16a swap and but I can't get it to run. It is getting fuel, I changed the filter and there was gas trickling out of the fuel lines. Any ideas?
Got a code 6 on the ecu but a temp sensor shouldn't stop it from running....or should it? Ohms read 4.2 on the sensor and 2.6 on the plug. Disconnected battery a couple times but code is still there.
Old 02-25-2004, 02:52 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: She cranks...
do you have the distributor hooked up correctly (wires to sparks in correct ones)? is your timing correct? and no a temp sensor should'nt stop it from running, but I suggest you replace it VERY soon.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-25-2004, 06:48 PM
SP_Mark SP_Mark is offline
Re: She cranks...
try some starting fluid!!!
Old 02-25-2004, 10:22 PM
defman's Avatar
defman defman is offline
The same problem happened to me. My problem was the distributor was 180 degrees out of time. in other words upside down. that may be your problem.
Old 02-26-2004, 12:11 AM
Re: She cranks...
Plug wires are where they should be, did the timing belt again: hash marks on the cam sprockets were lined up, both sprockets were in the "UP" position, lined mark on crank with housing, rotor was pointing towards #1, started belt from crank to tensioner then to h2O pump then to cams, 3 teeth couterclockwise, tightened tensioner....still no go.
If the ecu only flashes once and never again then I'm wrong on the code 6, I think. After initial flash i get this code over and over: 1 long flash then a decent pause then 6 quick flashes. 10 & 6? 1 & 6? 16? I suck at this!!!!!!!
Old 02-26-2004, 10:12 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
thats a code 16.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-26-2004, 01:56 PM
Re: She cranks...
code 16 fuel injection guess what...no power to injectors. I have power from the "A" ecu harness to the plug (16p) in engine bay but lose it at the injector harness, resistance of each injector is 2ohms manual states 1.5-2.5
I currently have the heated 4-wire O2 sensor spliced (inline, no butt connector) into power supply line (yell/blk) before the 16p plug, sensors heats up nicely. I removed this splice, temporarily electric taped the yell/blk wire and still no go.
Looks like bad injector harness, or least bad power line in the harness? Is the injector harness off my HF motor compatible? Is the way I had the 4-wire O2 alright?
Old 02-26-2004, 10:25 PM
Re: She cranks...
OK let me start over. Last reply was the first I ever used a multimeter and I took a couple false readings....i'm an idiot. Now that I'm edumacated...I have resistance and voltage where I need it. A1,A3,A5,A7 wires all tested good from the injector to the ecu...no breaks. I also replaced the ect sensor since I had already bought it. The ecu code goes like this: flaaaaaaaaaaaash _______I can count to 4 during this pause_______flashflashflashflashflashflash. Even with this code shouldn't the car start? Is there anyway to tell if the injectors are squirting? Will it hurt anything if I turn the dizzy 180 and dont need to? Help!
Old 02-27-2004, 09:06 PM
Re: She cranks...
Plugged a noid light into all for injector plugs and all 4 lit up so the ecu signal is getting to the injectors. Tried to turn the dizzy 180 degrees but only the left side of the shaft went all the way in. Right side there was about a 1/4" gap between the dizzy housing and the mount. I could have probably got it flush by tighening the bolt but not sure if that would mess anyting up. Any other ideas as to why she wont start or where to look next?
Old 02-29-2004, 08:17 AM
Re: She cranks...
Turns out I have a broken wire. After changing Main relay and trying to start the car I touched the drivers side door skin and got a nice little shock. Talked with previous owner and he said there was repair work done to the drivers side door and surrounding areas last June. A few months after the body work he was having trouble with the battery running out of juice. So I'm looking for a wire in that area that is fuel delivery related hence the code 16.
fyi...you can't turn dizzy 180 out on a b16a
Old 03-01-2004, 11:26 AM
crxsirpr crxsirpr is offline
good luck had same problem with mine,crx b16. it wouldnt start it just went clack! once then nothing it was a faulty wire. check the fuse box in the back there are a lot of wires there and take the panels from the steering wheel off and chek the ignition wires.
Anti-Theft Window Crank Device ? Intuit Escort 6 10-11-2011 03:00 PM
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 07:25 PM
1998 Express Cranks but no Start kmckev2 Express | G Van 5 01-07-2010 12:26 PM
2000 gtp - crank sensor replacement kozmosis Grand Prix 2 08-27-2009 11:18 AM
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 12:02 PM
