98 Strarus Tie Rod End
My son broke the driver's side tie rod end on his 98 Stratus. I bought the part and proceeded to remove the broken tie rod end. The broken ball joint section came right out. The part that threads into the rod is frozen tight. I have tried anti-seize lubricant, heat and even pipe wrenches and it won't move.
Is there a trick to removal? How can the entire assembly be removed? Anyone have any suggestions? |
Re: 98 Strarus Tie Rod End
Lots of heat on the locknut..........ie cherry red if need be. Then crank on the tie rod end................driver's side?? Counterclockwise!!
Re: Re: 98 Strarus Tie Rod End
I have the locknut loose. I can't break loose the tie rod end itself. |
