Old 02-24-2004, 07:35 PM
ugination87's Avatar
ugination87 ugination87 is offline
noob question about turbo timer
ok i kno this will sound weird but what dus a turbo timer do? someone told me like it keeps ur car running for like 5 minutes after you turn it off to cool the turbo off so it wont mess up? can someone explain waht it dus?
Happiness is around the next corner.. all shapes and sizes
Old 02-24-2004, 07:37 PM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Re: noob question about turbo timer
That is sort of what it does... A turbo timer will keep your car running after you remove the key to let the turbo cool down... The length of time it runs depends on the strain you put on your motor..
Old 02-24-2004, 08:00 PM
thats all?
do u know alot about cars? cuz if u do i have questions on what some parts dus.
Old 02-24-2004, 08:04 PM
Yeah I know my fair share... I'll try to help you out
Old 02-24-2004, 08:09 PM
ok first off what dus a boost control do?
Old 02-24-2004, 08:13 PM
and what dus headers do?
Old 02-24-2004, 08:17 PM
A boost controller lets you manually control how many pounds of boost your turbos put out. Turn it to a higher psi to get more power and vice versa...
Old 02-24-2004, 08:20 PM
so u can set it on the control panal to how much boost u want?
Old 02-24-2004, 08:21 PM
As for headers... aftermarket ones are larger in diameter and allow more airflow in... They give you more power in higher RPM's
Re: Re: noob question about turbo timer
yeah you can
Old 02-24-2004, 08:25 PM
nice hmm o yea fuel injectors? do you need to replace that? or no
Old 02-24-2004, 08:26 PM
o yea and side skirts do they do anything except look good?
Old 02-24-2004, 08:30 PM
Fuel injectors... I'm not too sure, but I think you only need to upgrade them if you get bigger turbos or more power... Don't quote me on that though
And no, side skirts are only there for aesthetic value =)
Old 02-24-2004, 08:32 PM
hah nice ... waht is the difference between propane and nitrous injection? seems like nitrous produces more power?
Old 02-24-2004, 08:53 PM
Igovert500's Avatar
blue + red light magnet
Nitrious is designed to cram more air (oxygen) into you engine, therefore if adequate fuel is mixed with it, you get more combustion, therefore more power. Propane is used to get the most boost possible while using regular gas. propane is really high octane that mixes with your pump gas and allows you to turn up your boost a few more psi without getting knock and destroying your engine. So, what you are saying is correct, injecting nitrious does give you more power (directly) but propane's job is to allow you to produce more power with your turbos.
Few question about turbo timer Killa Off-Topic 1 07-15-2006 10:28 PM
Question about Turbo Timers rodbls Eclipse 2000+ 1 05-11-2005 08:29 AM
noob question about dsm turbos londa hover Engine, Transmission and Drivetrain 15 03-25-2005 12:27 PM
noob question about dsm turbos londa hover Off-Topic 3 03-15-2005 09:00 AM
Question about Turbo Timers.. Vtec95Civic N2O | Turbo | Superchargers 6 10-21-2004 05:07 PM
