Old 02-24-2004, 05:31 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Microsol dissolves tamiya acrylic?
Just a heads up. I painted my window trims with Tamiya Acrylic flat black (XF-1), let it dry about 2 hours, and then started decalling some complex curves next to the trim. The microsol seems to have stripped the black paint, then, through capillary action, sucked it all up under the decal. It's now visible under the decal. (White car, so black under a decal really stands out). I think I'm going to try to soak under the decal with microsol, then use a paper towel and draw out the microsol with the black paint again, taking care not to damage the soft decals.
Anybody else experienced this before?
I work slowly!
Old 02-24-2004, 05:45 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Hmm...I've never had any thing like that happen to me, its made my decals crack, but once it dried they were all smooth again, no cracks..it was weird, something about fujimi decals, because that always happens with them
Old 02-24-2004, 07:00 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
Re: Microsol dissolves tamiya acrylic?
I sometimes use Future Acrylic floor wax to clear coat models. Once, I applied it about 5 hours after decaling with SMS CF decals and the decal wrinkled up. It was on the bottom of a car, so I didnt do anything about it, I just left it. About one month later, it flattened out again. The lesson I got from this is to be absolutely sure the decals are dry before clear coating. I now wait 2 days to clear coat after decaling and I have not had any problems since.
Old 02-24-2004, 07:06 PM
p9o1r1sche's Avatar
Registered User
I may not have been clear in my last reply, so...
Microsol is an alcohol and acrylics are usually thinned with alcohol, so if the acrylic paint wasnt FULLY cured, the Microsol will dissolve it. Just be patient and make sure one operation is completely finished before starting the next. (Yea, sometimes it takes me more than a month to finish a model)
Old 02-24-2004, 09:17 PM
RallyRaider's Avatar
Zomby Woof
Re: Re: Microsol dissolves tamiya acrylic?
Conversely, I've hardly ever made one in less than a month! Or even three it seems.
Thanks for the warning DSM-Mark, it may help to convince others of the need for patience.
Old 02-24-2004, 09:24 PM
Vric's Avatar
Vric Vric is offline
never happened to me
Old 02-24-2004, 09:37 PM
scaleracecars scaleracecars is offline
Microsol and Microset are also hard on lacquers. All lacquers can be dissolved with alcohol and it can leave what look like water spots in the finish. I would think you really applied a lot of microsol and let it set to have this problem. If it was only a little you probably had thinned the paint too much before painting.
Old 02-25-2004, 08:07 AM
Ken B. Ken B. is offline
Send a message via AIM to Ken B.
Maybe you should have waited longer, say 24 hours before applying the MicroSol? Thats my only suggestion to your problem. Its never happened to me before, and I use MicroSol and SolvaSet over Tamiya acrylics on a daily basis.
Old 02-25-2004, 11:28 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
I doubt you're going to be able to remove much black paint from the decal. More than likely, the pigment has stained the decal film. Good luck, and let us know if it works.
tamiya acrylic paint that is closest to Tan? SupercarFreak Car Modeling 12 04-09-2003 04:41 PM
For those who use Tamiya Acrylic in the bottle.... BaNe Car Modeling 3 03-11-2003 12:41 PM
Tamiya Acrylics, grainy texture... djmr2 Car Modeling 5 01-14-2003 07:41 PM
Tamiya Acrylic Paint *NOT* mini djmr2 Car Modeling 6 08-17-2002 03:55 AM
Tamiya acrylics nismo kid Car Modeling 4 02-28-2002 05:18 AM
