Old 02-24-2004, 05:24 PM
automan53 automan53 is offline
1995 Cruise Control problem
The cruise control will only stay engaged for a few minutes at best, sometimes for only 5 seconds or so. Once it drops out, it cannot be re-engaged until the engine is turned off and restarted.
What do I look for? Many thanks.
Ron
Old 03-24-2004, 07:51 AM
avatar307's Avatar
avatar307 avatar307 is offline
Re: 1995 Cruise Control problem
I had a similar problem. Whenever I turned on the A/c the cruise control would die. I would have to stop the car and shut off the engine before it would work again. It ended up being two sensors on the front of the engine that... controlled the fans I believe. When you turned on the A/c it kicks on the second fan and that in turn killed the cruise some how. No one knew which sensor to replace (there are two of the same) so they just picked one. Apparently it worked, I haven't had the problem in years. -C
Old 04-20-2004, 01:52 PM
creslevi creslevi is offline
my cruise was installed aftermarket, but by the dealer it is OEM, when he spurred onto one of the existing wires with a scotchlock it was too big for that wire and eventually lost connection, it took many hours of looking and testing by some very smart techs that could'nt find the problem before another Buick dealer tech found it and showed it to me, now its worked great for years, but I have an intermittent problem with my trunk release that was also added at the same time, I suspect the same thing with it but am too old and achey to work under the dash anymore, hope this helps Rick
Old 05-21-2004, 09:49 AM
waynen waynen is offline
Ron
I would like to know what you found out. Mine does the same thing.
Wayne Nelson
[email protected]
Old 05-30-2004, 07:09 PM
Bassasasin Bassasasin is offline
Talking I FIXED IT! >>>Cruise Control 94'
I took apart the cleaned vaccuum servo...brake vaccuum release solonoid (sounds harder than it is)
Remove the intake flex hose with a 1/4 drive socket just to make it easier.. Remove the vaccuum servo.. 3 5/32 screws.. and 2 hoses and throttle cable clip.. remove control electric plug...
ON a clean bench, being careful to hold with the cover being removed up remove coil cover ( 2 torx) don't break any wires.. .. Look at the top of the coils one will have a silver solonoid piston showing..
Carefully turn over unit on a clean table and tap out this solonoid piston plunger and a needle valve should follow, usually they fall out. With a paper towel clean plunger and hole it goes in.. clean needle valve (rod)ends .. If you want to clean the needle seat use a toothpick and lightly clean the seat deep in the hole I didn't do this and it still worked great! If you try this you can't see the seat maybee you can feel for it.. dont break off the toothpick.. a light cleaning no pressure one turn or 2 should do the trick .
Get all the brown stuff off.. no solvents..I sucked and blew on the large vaccuum connect hole while pressing the silver piston while it was still dissassembled to verify whats going on and such. Dirty me!
Reassemble in reverse putting the shiney neeedle end in first..
THATS IT>>>>
Dan.. In omaha...
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 05-30-2004, 07:28 PM
I took apart "AND" cleaned the vaccuum servo OOPS
Tanks..Dan (bassasasom)
Old 05-31-2004, 08:56 AM
Thanks for the information. Will give a try. Will let you know if it works.
Waynen
UOTE=creslevi]my cruise was installed aftermarket, but by the dealer it is OEM, when he spurred onto one of the existing wires with a scotchlock it was too big for that wire and eventually lost connection, it took many hours of looking and testing by some very smart techs that could'nt find the problem before another Buick dealer tech found it and showed it to me, now its worked great for years, but I have an intermittent problem with my trunk release that was also added at the same time, I suspect the same thing with it but am too old and achey to work under the dash anymore, hope this helps Rick[/quote]
Old 05-31-2004, 04:21 PM
My LeSabre would flash cruise while I pressed and it would flash off. sometimes work and sometimes slow down with bumps in the road.. The servo sucks air from the engine compartment right into that valve.. I guess it gets dirty eventually. 178k miles here.. Heh..
Old 06-01-2004, 09:51 AM
Re: Re: 1995 Cruise Control problem
Thanks for information. Will give a try
waynen
Old 06-01-2004, 09:53 AM
Thanks for info. Will give a a try
waynen
Old 06-01-2004, 09:55 AM
Re: I FIXED IT! >>>Cruise Control 94'
THATS IT>>>>
Dan.. In omaha...
Thanks for Info. Will give it a try waynen
Old 08-27-2004, 05:46 PM
My problem came back.. eventually.. Apparently the PCM records the error of the vacuum vent side of that cruise servo.. If it doesnt see the proper resistance it errors. It appears it totals up the errors and kills the cruise control..
The latest is what I am experiencing..
Cruise was definately INOP. I replaced the Servo. Cruise worked about 5 times in a row and quit... practically permantely.
I coughed up the bucks for a PCM and the cruise came back. For two days now I have cruise. The error may be errased..
Maybee just resetting your PCM errors will fix it but I replaced it .. DUmb Me... whatever.. thus starting over..
SO.. its working today.. tomorro who knows..
Old 08-27-2004, 07:16 PM
I refer you to post # 3 on this thread, Once I found the bad connection with that scotchlock its worked ever since perfectly, But I still have an intermittent problem with my dash trunk release, Hopethis helps
Rick
Old 08-28-2004, 10:18 AM
I had my servo cleaned. Put on a new rebuilt one, still didn't work, so put another rebuilt one on, then the codes changed, so mechanic looked up on the Web site that they have, showing the problems listed by General Motors. Said to change the switch behind the brake pedal. Put a new one on, and so far it works. The switch costs the mechanic $5. He didn't want to charge me for it, but I paid him something anyway.
Have your mechanic put up the information on the computer. It explains and has detailed drawings of the servo, and the brake switch, on how it is to be
set.
Waynen
Old 08-28-2004, 02:34 PM
Waynen
OPINION..
A cruise control running then dropping out is pointing to a vacuum leak on the vent side of the servo especially for periods of more than 2 seconds. When the Cruise light doesnt even light I would suppose a code is in the PCM disallowing the system till a power cycle.
WAYNEN
I had suck checked mine (pheew! ) and there are no vacuum leaks to the pedal. The large rubber hose to the Cruise servo is that brake pedal line.. I but symptom does match the ."works for just a flash" Also the leaky valve in the servo would be the same vent as a press of the brake pedal.. anyway as of this post New PCM has worked for 2 days.. wish me luck. You guys are cool.
RICK.
. as for your connector.. I dug down there and found no connection.. yet.. heh. .PS Rick take a short pipe for a tool and increase the trunk lid springs enough to just open all the way. I like it.
1995 ford f150 cruise control problem jonesrsrg F Series 3 01-27-2010 07:42 PM
94 Ram no cruise controll mrkabokieman Ram Pickup | Ram SRT10 3 08-16-2009 03:36 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
j30 1995 cruise control not working andyrjk Cedric | M45 | J30 | Gloria 1 10-04-2008 10:44 PM
