Old 01-23-2010, 11:38 PM
jonesrsrg jonesrsrg is offline
1995 ford f150 cruise control problem
i have a 1995 ford f-150. when u activate the cruise control the accelerator keeps moving accelerating then decelerating. tried setting it at different speeds but still does the same thing. its causeing me to get crappy fuel milage. any help woukld be greatly aprerciated.
Old 01-24-2010, 09:18 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 1995 ford f150 cruise control problem
Check the vacuum hose going to the servo. It may be cracked or the diaphragm in the servo has a hole in it. The servo is connected to the throttle linkage. There may not be enough vacuum present to operate the cruise when going up a steep hill. You can compensate for that by installing a vacuum reservoir. Route the vacuum source to a cannister so you have enough vacuum to operate the cruise. You'll have the vacuum source going in and the vacuum source for the cruise going back out again.
Old 01-25-2010, 09:18 PM
thanks for the reply. i looked at the servo used a vacum tester it seemed to hold fine also checked the vacum hose. it looked a little wore so i went ahead and replaced it. stil does the same thing. i was told there might be a adjustable screw o it somewhere so u ca adjust the cruise control. if so where might it be and how would u go about adjusting this correctly. it seems to be getting worse.
Old 01-27-2010, 07:42 PM
dfordski's Avatar
dfordski dfordski is offline
Is it a single cable unit & throttle cable, or dual cable unit & throttle cable? If it's the single cable, it could be the VSS that fits on the end of the speedo cable & that, fits into the transmission. Two wire connector. Acts like it falls out, then cuts back in? Changed mine this week. Part $57./10 minutes of elbow grease. However if it's 2 cable, can't help ya. No idea how that works.
"Saving the World......One Ford Truck at a Time!"
