Old 02-24-2004, 04:45 PM
FrostyTech FrostyTech is offline
Post 97 Accord EX 5spd CEL Code 65 - Please read
Greetings.
The Check Engine Light on my Accord came on this past Saturday.
I did the usual, check gas cap, drive 3 times, reset ECU by disconnecting battery.
None of this helped.
Although, car still seems to run fine.
No clue on a change in fuel economy yet.
I finally jumpered the ECU and got the code..
Code 65 - Oxygen Sensor Heater (Secondary?)
Upon getting the code, I reset the ECU again.
I then proceeded to crank the car and let the ECU flag the CEL again.
It didn't.. I'm guessing the sensor is going bad, but sporatically working.
Would someone please be kind and describe to me whether this sensor is located? Is this the O2 sensor mounted on the top side of the exhaust manifold shortly past the oil pan before the catalytic converter? Or is the O2 Heater a difference sensor?
Many thanks in advance.
Old 02-24-2004, 08:44 PM
LX-biker LX-biker is offline
Send a message via ICQ to LX-biker
Re: 97 Accord EX 5spd CEL Code 65 - Please read
Originally Posted by FrostyTech
Greetings.
You to.
Coz computer "forget" about bad sensor and run with default programm...
Yep.
May be bad connection of heater circuit.
Located on exaust after catalytic converter.
Secondary Oxygen Sensor have additional Heater circuit (Pins 3 and 4 on Mine 98 Accord-sorry if different in yours). You can find wire from O2 sensor, disconnect connector and measure resistance between those pins. Should be between 10...40 ohms. If yes, need to be checked voltage 12v on opposite side when engine is ON. If NO-you need new sensor.
Luck!!!
Old 02-25-2004, 10:05 AM
Re: Re: 97 Accord EX 5spd CEL Code 65 - Please read
Ah, ok, defaults to failsafe settings to keep it running
Luck!!!
Awesome man!!!
Exactly what I needed to know.
I just looked underneath and was able to identify the sensor you're referring to after the catalytic converter. Since it's raining here, I'll have to wait till tonight and pull the car in the garage to do the OHM and VDC checks. That's great info man. Many thanks.
So far, after resetting the ECU for the 7th time, the CEL hasn't come back on. I have driven it 4 times since then, which was yesterday afternoon. A buddy mentioned I may have gotten 'bad gasonline' and it freaked out the ECU. I will still do the OHM and VDC checks tonight just for grins. I'll keep an eye on it. If/when the CEL comes back on, ASAP I'm going to jumper the ECU to ensure I get another Code 65.
One last quick question. I priced this Secondary O2 Heater.
OEM = $150 USD, Aftermarket = $65 (entire kit too).
Since I'm probably going to have to replace this in the future, which would you suggest? OEM or Aftermarket?
Old 02-26-2004, 06:40 PM
Hi,
Forget one thing:
bad contact in the mentioned connector may be cause too...
About aftemarket depend of brand-some good some not. honestly I not expert with O2 sensors makers, just know few famous like Bosh...
You can try cheapy if labor not expansive or you do byself.
Old 03-10-2004, 08:12 PM
Talking UPDATE: Problem solved
I replaced the Secondary O2 sensor and everything is fine now.
No Check Engine Light, gas mileage has returned to normal, and the engine runs much better than before the heater in the sensor went bad.
FYI: I ended up buying the OEM Denso part from www.alloemautoparts.com for $174 (free shipping)
I searched roughly 2 dozen 'OEM' online parts outlets..
Most wanted $187..
Local Honda dealers wanted $237 (hahaha, no thanks)
Aftermarket with OEM connector wasn't much cheaper than alloemautoparts.
The cheapest being $70 had pigtails instead of the OEM connector.
I've saved myself about $200 total
(Diagnosis, Parts, and Labor)
I'm happy
Thanks LX-biker for the help.
Appreciate it.
Old 03-10-2004, 10:01 PM
Nice, Nice!
Congrat!!! & _/\_ for dealers blood suckers...
85$ + tax in Canada for what I did for 1 minute and jumper wire? OOOO that is hi-tech stuff realy....or kids stuff
take care.
Former moto biker.
1997 Accord EX 2dr 5spd - CEL code 71 - Misfire FrostyTech Accord/TSX/Accord Hybrid 9 10-10-2006 10:22 AM
CEL on again. Please read david-b Off-Topic 6 02-13-2005 08:55 PM
2000 accord 1/4 time. Please read. electronblue Accord/TSX/Accord Hybrid 17 03-21-2004 09:42 AM
Those of you with a 5-speed accord and with a VAFC please READ!!! Drkknight99 Accord/TSX/Accord Hybrid 6 05-17-2003 01:47 PM
GDS Security for Honda Accord / Please READ! software23 Car Audio 1 01-22-2002 06:04 PM
