Old 02-24-2004, 01:19 PM
drknow drknow is offline
no heat
I have a 94 escort and recently the heat went out on me. the blower is not working at all. Also the no coolant light is on, even when the resevoir is full. Any ideas?
Thanks
Old 02-27-2004, 05:24 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: no heat
first thing I would check is the fuse for the blower. If the fuse is good, bad news... you want the fuse to be bad... get it?
Filling up your resevoir should take care of the no coolant light... maybe the sensor in there is on the fritz.
Old 03-01-2004, 01:08 PM
thanks for your reply...I did check the fuse and it is good. I guess that is bad news for me then. Would you have an idea as to what the problem might be?
thanks again!
Old 03-01-2004, 04:19 PM
Re: no heat
There are three things you should look in to then...
1. The switch is bad (not likely)
2. The blower resistor is bad (very possible)
3. The blower motor is bad (most likely)
Use a multimeter and check for continuity through the electrical connector at the blower motor.
I am not sure how to go about testing the resistor other than changing it (which is very easy).
If you have the means to do it, it will be easiest to just plug in an alternate power source to the blower motor. If it runs, then either the switch or resistor are bad.
Old 11-07-2004, 09:42 AM
casima2224 casima2224 is offline
I actually have a similar problem, and I want to check the fuse, but cannot find the location of the heater fuse. It is marked on the fuse box under where the left foot should be, but the corresponding fuse is not there. Is there somewhere else I should be looking? I have a 1994 Ford Escort.
Please help!
Thanks
Old 12-21-2004, 11:13 AM
townsaver townsaver is offline
Send a message via Yahoo to townsaver
Re: no heat
I had a similar problem, once, too. What fixed it for me was unplugging nad replugging in the blower motor, which, IIRC, looked just like a 3 prong 60Hz plug for an outlet, down under the glove compartment in the passenger seat.
unplugged, and replugged, and the blower has worked since. Same thing happened to my sister with her tracer, my dad found it. I called him for advice on my issue, that was his suggestion, and lo and behold, it worked!
Old 12-23-2004, 09:44 PM
panzees36 panzees36 is offline
Send a message via Yahoo to panzees36
My heater fan on my 1997 Escort quit working and it was just the resistor,
Old 12-28-2004, 10:10 AM
thirtyfootpush thirtyfootpush is offline
Re: Re: no heat
The fuse panel located by your left foot does show the heater fuse on the list, but I believe it is actually located just above the fuse panel to the right. I think you have to flip up a little door to check it. It isn't a colored fuse like the others.
no heat/mixed heat jbmx4life Grand AM 7 02-11-2006 01:37 PM
Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! eahockeygod Metro 3 01-10-2005 08:00 PM
No heat when stationary, heat when moving. girardmn Sable 3 03-22-2004 08:50 PM
Heat then No Heat randyman C/K 3 12-11-2003 02:25 PM
