Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-24-2004, 12:07 PM
germ79 germ79 is offline
A couple problems with the Aurora!
I was excited to finally find an Aurora forum, so now I have some questions.
1. I am getting some leaking that appears to be dripping from my right rear shock. Is that normal for a bad shock to do or is it something else?
2. My traction control/abs lights are on all the time now, but it seems that is a common problem for our cars. I'll try some of things I read like topping off the brake fluid before I go and have the bearings and sensors replaced.
3. A couple times my check engine light has come on (doesn't stay on too long-usually goes off after a couple trips in the car) and I got the code read at AutoZone one day while it was on and it came up with something about a engine turbine speed sensor or something to that effect. I am guessing this has something to do with the transmission--which scares me. I'm not willing to invest $3000 into this car.
So, should I be worried about the turbine speed sensor? Should I trade this car in before it's too late?
Thanks!
Jeremy
>>MY 97 WS6<<
**NEW PICS TAKEN 1/7/04**
Old 02-24-2004, 01:56 PM
gates455cutlass gates455cutlass is offline
Send a message via AIM to gates455cutlass Send a message via Yahoo to gates455cutlass
Re: A couple problems with the Aurora!
yoiu have a car with age on it...you will have to replace things like the bearings with the sensors or simply put up with the light. As for the shocks, it is time for a new set it sounds like to me.
2002 Dodge 1500..."No, it doesn't have a hemi!", 70 CUtlass SX (455), (3) 95 Olds Auroras, 77 olds salon T top(403)
Couple Problems with 93 Lebaron Vert carb0n03 Lebaron 0 05-15-2007 12:04 PM
couple problems with 92 rodeo matemk Rodeo | Passport | MU 2 08-23-2005 09:28 PM
Problems with 96 Aurora dacreezx Aurora 1 06-05-2005 02:38 AM
couple problems with an 86 cavy savage8190 Cavalier 5 01-05-2005 08:18 PM
Problems with 98 aurora casey38boost Aurora 1 12-18-2004 01:51 AM
