Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-29-2005, 12:23 AM
matemk matemk is offline
Send a message via AIM to matemk
couple problems with 92 rodeo
1.) Some of the lights on the dash work and some dont. the 2 around tachometer work lighting up the left and right side of it but not the top, and nothing else lights up. anyone experienced this before?
2.) rear window wiper does not work
3.) Tail Gate Opener button does not work
anyone have any ideas?
Old 08-23-2005, 04:45 PM
kmathew kmathew is offline
Re: couple problems with 92 rodeo
1. Lights burnt out bulbs Will need to pull,dash apart to replace.
2. Fuse or fried motor
3. Most of the door and tailgate systems have small plastic parts that hold them together. On a 92 model more then likely you have a part that has come loose or has broken. This is usually a problem with normal wear and tear. Take apart the latch assembly and see what is broken.
Old 08-23-2005, 09:28 PM
BULLITTR6 BULLITTR6 is offline
Send a message via Yahoo to BULLITTR6
Does the rear hatch window fully close and lock? If it doesn't, the button will not work nor will the wiper. There is a sensor for it, and if the glass does lock, then the sensor doesn't know it and things won't work.
Good luck.
1991 F350 dually w/ 7.3 deezal
2008 Mustang GT
1993 Rodeo LS w/ 3.2 v6, 2wd (daughters)(Now totalled)
1991 Yamaha XT600
1993 Honda CR250R
Hard tellin', not knowin'
