Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-24-2004, 12:02 PM
info_cker info_cker is offline
Question 95 transmission question
my 95 neon had started having shifting problems only when it is cold. when i first start it in the morning, if i put it in reverse it pauses before going in gear and then sort of "clunks" in gear. if i put it in drive first and go forward a few inches then put in reverse i don't have the problem. then when i start driving it doesn't want to shift into third. it'll shift out of second and i usually am coasting for a while then it will go into third. again this only happens when it is cold. if i park for a only a couple hours and start again i don't have the problem...thought it might just need a fluid and filter change...any other ideas?
Old 02-24-2004, 01:32 PM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Re: 95 transmission question
A fluid/filter change does seem in order (see HERE for that).
However, you may also want to look into adjusting the atx bands while your in there as well.
L8R,
~NeonStyl
- www.neonspeed.com -
transmission question about switching 91 transmission with an 88 justgotwicked S-10 1 05-31-2005 09:29 AM
transmission questions SCMaxima2k Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 02-05-2002 08:43 AM
Transmission question Steel Engineering/ Technical 2 10-21-2001 01:56 PM
