Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-23-2004, 07:09 PM
Unlawful 240sx Unlawful 240sx is offline
Send a message via AIM to Unlawful 240sx
Multiple Problems 95 aurora ANY HELP WOULD BE GREATLY APPRECIATED
This is all for a 95 Aurora. I will start with the main problem. The transmission. As the tranny is entering reverse it jerks quite hard as if somebody ran into me from behind. Putting it into drive is similar but not as hard of a jerk. Now the fun part, while I am driving: It feels as though I am starting out in 2nd or maybe 3rd. Whichever gear its in when I start to accelerate from a stop it stays in no matter how fast I go. IT WONT SHIFT. I will only drive it to about 35 mph then the tach reads about 3500. I wont go above that cause it sounds unhealthy for the engine and tranny. Now there is a Service Engine Soon light on and the Airbag light is on as well. I looked at the tranny fluid level while it was hot and it looked to be a little high. These are the latest problems. Yesterday it was a whole different list of problems. Yesterday the cooling system wouldn't fill up (the upper hose, lower hose all wouldnt fill with coolant). The DIC said Check charge system on it and the VOLTS light was on. But the transmission was working perfectly yesterday. Smooth as could be shifts and just the right timing. Now today all of the problems above are occurring while the cooling system is now filled up the check charge system on the DIC is no longer on and the VOLTS light is no longer on.
I called up the dealer to ask them about the IDLE LEARN TEST. This test is for after you unplug the battery for getting the computer to relearn the idle or something like that. They said they would charge me 70 bucks to do it. So then I called a local garage and they told me how to do it without a scan tool. So today I did what they said. Which was, start the car put it into drive with the parking brake on and let it idle in gear for 2 fan cycles. I did exactly that and the service engine soon light went off after I put it back into park and then came back on about 5 seconds later. And thats where I am up to now. Please help me figure something out. Im leaning towards a computer malfunction or some kind of false code. Also on another note is it healthy for the battery voltage to be running around 18 volts while the car is running and driving.
As always any help will be greatly appreciated.
Old 02-23-2004, 07:12 PM
Re: Multiple Problems 95 aurora ANY HELP WOULD BE GREATLY APPRECIATED
One other thing I forgot to add. Now the ABS and Traction Control lights are no longer on. The Traction Control is actually functional now as in I can push the button and it will turn on and off. Before pushing the button didn't do anything. So maybe that IDLE LEARN TEST may reset the ABS and Traction Control system and turn the lights off.
Old 02-23-2004, 08:02 PM
flaurora flaurora is offline
Send a message via MSN to flaurora Send a message via Yahoo to flaurora
Good luck with the tranny I had the same problems with mine but once it started it never got any better as you say yours did. Mine had a complete rebuild for about $2800.00. But she runs great now. Hope you have better luck. One thing the guy who rebuilt mine said that it might not be a big deal about $100 bucks or so but It turned out different for me if yours is not staying that way it might be something simple. In anycase take it to a tranny specialist that you trust. I will call him and ask him what he origianly thought it was. the $2800 made me forget.
Old 02-23-2004, 09:13 PM
BKVic's Avatar
BKVic BKVic is offline
With that many things going wrong with it I would say your best best is to take it to a dealer and have it hooked up to the computer and have the codes pulled. Best of luck!
BKVic
Old 02-24-2004, 01:46 AM
Indy8's Avatar
Indy8 Indy8 is offline
A stick of dynamite?
Quality isn't expensive, it's priceless.
Old 02-24-2004, 08:18 AM
davidray davidray is offline
you have to love the northstar tannys. I agree with flaurora, take it to a transmission shop. The clunking in the tranny is caused by the fluid pressure being raised, expecially in reverse. It takes more pressure for reverse than it does in any other gear, thats why reverse is worse. Check to see if there is a code for the "speed input sensor". As far as all the other shit going on, good luck on that one, maybe a computer. I had 7 different codes at one time, a computer cleared everything up. Hope this helps!
Old 02-24-2004, 01:59 PM
gates455cutlass gates455cutlass is offline
Send a message via AIM to gates455cutlass Send a message via Yahoo to gates455cutlass
Just dig a big hole and drive it into it...then put dirt and some flowers on it...lol, no serioiusly, you need to have it checked out by a professional.
2002 Dodge 1500..."No, it doesn't have a hemi!", 70 CUtlass SX (455), (3) 95 Olds Auroras, 77 olds salon T top(403)
Old 02-24-2004, 10:27 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
well I had some check engine lights come on. so i went to autozone and they checked the codes for me. there happened to be 12 but I cleared them and then he told me to come back it any one came on, well they did so i went back and they checked it again and it told me what the problem was. so I was able to fix it and paid nothing for the scan, so maybe you should go there find out what the scan tool tells you and post it up on here and maybe we can help you out.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-30-2004, 09:50 PM
dmorlow dmorlow is offline
You need to do what 97 silverbullet did. Have your codes cleared and then when the check engine light comes back on, take it in and check what codes are in the system. Then go from there. The traction and anti-lock brake lights are probably not on because after unplugging the battery for that long, you probably cleared the codes. But as soon as you take it for a nice drive, it will probably come back on. Just because you can push the traction button and the traction off light goes on and off means nothing. As soon as your check engine light comes back on and the traction off light is on steady, it will not change at all. I had that go bad in mine. It ended up being the pressure regulator valve. It cost me $700 to fix it. But that may not be necessarily what is wrong with yours. The only way to know for sure is to pull the codes from the computer.
BMW Mini Cooper chassis paint colors. Any help would be appreciated Exotics_Builder Car Modeling 6 05-22-2007 05:29 PM
Got a 92 accord has some issues, any help would be appreciated. Sconic Accord/TSX/Accord Hybrid 12 02-09-2005 02:57 PM
Electrical problems!!! Any help would be appreciated. drifting_FC3S RX-7 3 06-18-2004 07:56 PM
Corolla Troubles. Any help would be appreciated. illusionv6 Corolla/Matrix/Voltz 2 12-12-2003 02:50 AM
Any Help Would Be Appreciated :) JustBored Western US 4 01-26-2002 12:35 AM
