Old 02-23-2004, 06:49 PM
blmitche blmitche is offline
Unhappy 1985 Suburban Turn Signal problem
I am putting the steering column back together after the ignition actuator rack broke and a piece fell out of the turn signal housing portion of the column. I did not see where it came from and don't see where it will go. Is there anywhere I can get a diagram for this portion without buying a new one. The piece looks like it might make contact with something else. It is spring steel and roughly in the shape of an elongated "A" with a small hook at one end.
blmitche
Old 02-25-2004, 09:39 AM
dirty dan dirty dan is offline
Re: 1985 Suburban Turn Signal problem
As I recall, that is a contacter for you "key-in" buzzer. As you face the steering column, on the right towards the igntion switch there is a square hole. This piece goes in there open end first.
Any dealership parts dept should have a breakdown that you could look at.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 10:40 PM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 06:20 PM
85 Suburban Turn signal problem tamiii1 Suburban 2 01-01-2007 12:15 PM
97 Suburban Turn Signal Connection rollever2 Suburban 2 12-30-2006 06:56 PM
Suburban Turn Signals Tuffdrvr88 Suburban 0 12-22-2004 07:24 PM
