Old 02-23-2004, 07:32 AM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
Aoshima Wheels question
r the new s-type wheels, like the te37's male or female? how much work would it be to fit them to a fujimi car?
Old 02-23-2004, 08:06 AM
ywwong ywwong is offline
Re: Aoshima Wheels question
female.... i want to know how to do the conversion too.
Old 02-23-2004, 08:42 AM
V1nce V1nce is offline
How to convert rims - female to male
theres a how to on rim convertion
Old 02-23-2004, 10:19 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
To fit Fujimi you shouldn't need to modify the rims from female to male as most all Fujimi models have female rims.
At the moment I'm building a Tamiya R32 (male). I had zero problem fitting the S-part rims. I fitted them without grinding down the female accepters.
nightmaR3Z
Old 02-23-2004, 11:12 AM
im gonna put them on a fujimi v35 350GT, so no one sees any problems?
Old 02-24-2004, 05:54 PM
WeaPoN [X]'s Avatar
WeaPoN [X] WeaPoN [X] is offline
Yes there will be a slight problem, the fujimi Female piece is smaller in diameter than the aoshima piece. What i did to install Aoshima 19's on my Fujimi RX-8 was to grind the inner part of the disc brakes (the part where the female piece of the rim enters) till the rims fit. I used a dremel with some type of metal bit (forgot the name) but it was shaped like a small cylinder.
JeFF
